roml
March 28, 2019, 7:25am
1
I’m new with Mikrotik routers. Let me describe what I setup first:
I start from scratch and used QuickSet. I successfully set up the main WiFis and can join them + have access to the internet. Currently, I’m trying to setup Guest Wifi, but with no luck
I set name, pass, but when I’m joining Guest wifi (with MacBook or android phone) I’m getting the same issue:
- android tying to authorize and show me an error: сan not connect the Wi-Fi, check password and try again.
Looks like I’m setting the wrong password, I tried to change it, in security profile, but that has not helped me.
Can anyone help me?
I’m using “Mikrotik hAP ac lite”, RouterOS v6.44.1 (stable)
/interface wireless> print
0 name="wlan1" mtu=1500 l2mtu=1600 mac-address=B8:69:F4:D8:52:04 arp=enabled interface-type=Atheros AR9300 mode=ap-bridge ssid="MikroTik-D85204" frequency=auto band=2ghz-b/g/n
channel-width=20/40mhz-XX secondary-channel="" scan-list=default wireless-protocol=802.11 vlan-mode=no-tag vlan-id=1 wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no
bridge-mode=enabled default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no security-profile=default compression=no
1 R name="wlan2" mtu=1500 l2mtu=1600 mac-address=B8:69:F4:D8:52:03 arp=enabled interface-type=Atheros AR9888 mode=ap-bridge ssid="MikroTik-D85203" frequency=auto band=5ghz-a/n/ac
channel-width=20/40/80mhz-XXXX secondary-channel="" scan-list=default wireless-protocol=802.11 vlan-mode=no-tag vlan-id=1 wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no
2 name="wlan3" mtu=1500 l2mtu=1600 mac-address=BA:69:F4:D8:52:03 arp=enabled interface-type=virtual master-interface=wlan2 mode=ap-bridge ssid="ChaikovskyiHub1" vlan-mode=no-tag vlan-id=1
wds-mode=dynamic wds-default-bridge=bridge wds-ignore-ssid=yes bridge-mode=enabled default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0
3 name="wlan4" mtu=1500 l2mtu=1600 mac-address=BA:69:F4:D8:52:04 arp=enabled interface-type=virtual master-interface=wlan2 mode=ap-bridge ssid="ChaikovskyiHub1" vlan-mode=no-tag vlan-id=1
wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no bridge-mode=enabled default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no
/interface wireless security-profiles> print
Flags: * - default
0 * name="default" mode=dynamic-keys authentication-types=wpa2-psk unicast-ciphers=aes-ccm group-ciphers=aes-ccm wpa-pre-shared-key="30032019" wpa2-pre-shared-key="password"
supplicant-identity="MikroTik" eap-methods=passthrough tls-mode=no-certificates tls-certificate=none mschapv2-username="" mschapv2-password="" disable-pmkid=no static-algo-0=none
static-key-0="" static-algo-1=none static-key-1="" static-algo-2=none static-key-2="" static-algo-3=none static-key-3="" static-transmit-key=key-0 static-sta-private-algo=none
static-sta-private-key="" radius-mac-authentication=no radius-mac-accounting=no radius-eap-accounting=no interim-update=0s radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username
radius-called-format=mac:ssid radius-mac-caching=disabled group-key-update=5m management-protection=disabled management-protection-key=""
mkx
March 28, 2019, 9:22am
2
If you want to set-up guest access, then it’d be normal to define additional security profile … with different pre-shared key.
Other than that, I suggest to set same pre-shared key to both wap-pre-shared-key and wpa2-pre-shared-key . Even though you have only wpa2-psk enabled, it can still mislead you into using “30032019” as password instead of “password”. If both authentication types were enabled, it would create a major mess … because you never know which auth type will be chosen by a device while typically none will remember a password per auth type.
roml
March 28, 2019, 2:47pm
3
Thank you mkx , I start from different profiles and passwords, and tried to understand why I can connect with real (wlan1, wlan2), but can not with virtual. Steps by step make them close to each other.
I’ve checked ones more, but still can not connect to Mikrotik-guest1 or Mikrotik-guest2.
0 R name="wlan1" mtu=1500 l2mtu=1600 mac-address=B8:69:F4:D8:52:04 arp=enabled interface-type=Atheros AR9300 mode=ap-bridge ssid="Mikrotik1" frequency=auto band=2ghz-b/g/n channel-width=20/40mhz-XX secondary-channel="" scan-list=default
wireless-protocol=802.11 vlan-mode=no-tag vlan-id=1 wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no bridge-mode=enabled default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no
1 name="wlan2" mtu=1500 l2mtu=1600 mac-address=B8:69:F4:D8:52:03 arp=enabled interface-type=Atheros AR9888 mode=ap-bridge ssid="Mikrotik2" frequency=auto band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX secondary-channel="" scan-list=default
2 name="wlan3" mtu=1500 l2mtu=1600 mac-address=BA:69:F4:D8:52:03 arp=enabled interface-type=virtual master-interface=wlan2 mode=ap-bridge ssid="Mikrotik-guest1" vlan-mode=no-tag vlan-id=1 wds-mode=dynamic wds-default-bridge=bridge wds-ignore-ssid=yes
bridge-mode=enabled default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no security-profile=profile-guest
3 name="wlan4" mtu=1500 l2mtu=1600 mac-address=BA:69:F4:D8:52:04 arp=enabled interface-type=virtual master-interface=wlan2 mode=ap-bridge ssid="Mikrotik-guest2" vlan-mode=no-tag vlan-id=1 wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no
Security-profiles:
0 * name="default" mode=dynamic-keys authentication-types=wpa2-psk unicast-ciphers=aes-ccm group-ciphers=aes-ccm wpa-pre-shared-key="30032019" wpa2-pre-shared-key="30032019" supplicant-identity="MikroTik" eap-methods=passthrough tls-mode=no-certificates
tls-certificate=none mschapv2-username="" mschapv2-password="" disable-pmkid=no static-algo-0=none static-key-0="" static-algo-1=none static-key-1="" static-algo-2=none static-key-2="" static-algo-3=none static-key-3="" static-transmit-key=key-0
static-sta-private-algo=none static-sta-private-key="" radius-mac-authentication=no radius-mac-accounting=no radius-eap-accounting=no interim-update=0s radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username radius-called-format=mac:ssid
1 name="profile-guest" mode=dynamic-keys authentication-types=wpa-psk,wpa2-psk unicast-ciphers=aes-ccm group-ciphers=aes-ccm wpa-pre-shared-key="300320191" wpa2-pre-shared-key="300320191" supplicant-identity="MikroTik" eap-methods=passthrough
tls-mode=no-certificates tls-certificate=none mschapv2-username="" mschapv2-password="" disable-pmkid=no static-algo-0=none static-key-0="" static-algo-1=none static-key-1="" static-algo-2=none static-key-2="" static-algo-3=none static-key-3=""
static-transmit-key=key-0 static-sta-private-algo=none static-sta-private-key="" radius-mac-authentication=no radius-mac-accounting=no radius-eap-accounting=no interim-update=0s radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username
radius-called-format=mac:ssid radius-mac-caching=disabled group-key-update=1h5m management-protection=disabled management-protection-key=""
