Can not Ping New Router
This is a fresh out of the box config (with the exception of the IP set up) and I can not ping the internet from within Winbox. I have went through and tested firewall rules with no result. Is there something in my config that is not correct?
# 1970-01-02 01:56:59 by RouterOS 7.11.3
# software id = **ELIDED**
# model = RB4011iGS+
# serial number = **ELIDED**
add admin-mac=**ELIDED** auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp interface=bridge lease-time=10m name=defconf
/port
set 0 name=serial0
set 1 name=serial1
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf disabled=yes interface=sfp-sfpplus1 trusted=yes
add bridge=bridge interface=ether1
add interface=sfp-sfpplus1 list=WAN
add address=192.168.8.11/24 interface=bridge network=192.168.8.0
add address=**ELIDED**/29 interface=sfp-sfpplus1 network=**ELIDED**
/ip dhcp-client
add disabled=yes interface=sfp-sfpplus1
add address=192.168.8.0/24 dns-server=192.168.8.11 gateway=192.168.8.11 netmask=24
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes servers=8.8.8.8
/ip dns static
add address=192.168.8.11 comment=defconf name=router.lan
add action=accept chain=forward disabled=yes in-interface=bridge in-interface-list=LAN
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system note
set show-at-login=no
/system routerboard settings
set enter-setup-on=delete-key
/tool mac-server
/tool mac-server mac-winbox
You’ve given a static IP to the WAN interface but no route to it. Add something like this:
/ip/route/add gateway=sfp-sfpplus1
You should also remove sfp-sfpplus1 from the bridge, not merely disable it.
Thank you for the reply I am a total newb to Networking I am just trying to help a Non-Profit get set up and doing this pro-bono so any help is greatly appreciated!
I am a bit confused and to be honest a bit overwhelmed. I made all kinds of changes and decided to start from scratch. I reset the router without a default config and followed these instructions First Time Configuration - RouterOS - MikroTik Documentation
and this is the info from the ISP Link IP Address: 50.207.232.64/29
Gateway: 50.207.232.65
Layer 3 IP: 50.207.232.66 - 50.207.232.70
Layer 3 Subnet Mask: 255.255.255.248
Questions, Which address should I be using .64 or .66? Only the .64 address allows me to use the .248 subnet. This is the current export,
1970-01-02 00:43:22 by RouterOS 7.11.3
software id = BHZK-6XPY
model = RB4011iGS+
serial number = HG109TC046X
add name=bridge1
add name=WAN
add name=LAN
add name=dhcp ranges=192.168.0.1-192.168.0.254
add address-pool=dhcp interface=bridge1 name=dhcp1
/port
set 0 name=serial0
set 1 name=serial1
add bridge=bridge1 interface=ether6
add bridge=bridge1 interface=ether7
add bridge=bridge1 interface=ether8
add bridge=bridge1 interface=ether9
add bridge=bridge1 interface=ether10
add address=192.168.0.10/24 interface=bridge1 network=192.168.0.0
add address=50.207.232.64/29 interface=sfp-sfpplus1 network=50.207.232.64
/ip dhcp-client
add address=0.0.0.0/24 dns-server=0.0.0.0 gateway=0.0.0.0 netmask=24
add address=192.168.0.0/24 dns-server=192.168.0.10 gateway=192.168.0.10
netmask=24
set servers=8.8.8.8
add action=accept chain=input connection-state=established,related,untracked
in-interface=sfp-sfpplus1
add chain=srcnat out-interface=sfp-sfpplus1
add gateway=50.207.232.65
/system note
Please, please, reboot your router WITH default configuration. Your firewall rules are non-existent. Also you are publishing your Public IP address online…
As your ISP sent you, your network is 50.207.232.64/29, gateway is 50.207.232.65 and you can use addresses from 50.207.232.66 to .70. .71 is broadcast address.
Also what is this ??
