Can not route to subnet through RB750G from VPN tunnel
I have a IPSEC VPN tunnel, between 2 offices, an ASA5505 at main site, and NETGEAR VPN router at remote and the tunnel is fine and I can log on to the RB750 using web or winbox from remote side of tunnel but try as I may, I can not route to a subnet through the RB750.
I can however route to the subnet through RB750 from any PC or the server at the main site.
, i.e. I can log on to server and then get to further routers and machines on the other subnets.
Is this normal or am i missing something.
The RB750 is configured as a bridge with 2 ports, that is on its WAN side, ( at the time I did not realise I could have used the switch feature, it is mission critical with difficult and expensive access, so I can not risk changing it ) it has a single port on it’s LAN side which is connected to another router, NAT is not used.
And what is you L3 network map?
