CAn not setup ReuterOS
My reuterboard 450g works fine for couple of days. Suddenly the green led turn off. I try everything form net-install to hard rest etc… but no success. Do my board is fry? Also i noted that when look for the the default ip it seems not hte 192.168.88.1 insteda the ip i see is 169.254.2.100 / 255.255.0.0 in net connection details on win 8.
Any advice? Thanks
Do you hear any beeps, when power is applied?
Are there any actions with LEDs?
Yes it beeps 2 times. One beep at boot and 2 beeps after. The bard is in good conditions i dont see eny wrong or damages.
I heard normal beeps. Also check the board inside and seems no damages in the components.
Yes normal beeps. No board dammages or issues. I think the ethernet ports are damage.
2 beeps means that RouterOS is booted up successfully.
Access your device by MAC-Winbox, click on “…” to find and access device,
http://wiki.mikrotik.com/wiki/Manual:First_time_startup#Winbox
Thanks serjejs!
I do a 30-30-30 reset method 3 times and is live know.
