can not upgrade to 7.11.2
hi
I can not upgrade my mikrotik RB1100AHx2 from 7.10.2 to 7.11.2 . I got following error on log section : can not install lora-7.11.2: iot-7.11.2 is not installed, but is required. I tried online upgrading and manual upgrading but without success. please help me to solve this as I stuck on this version.
Manually add iot package to current install ?
Then upgrade.
it work,thank
I did that too but could not upgrade.
What message do you get ?
Also check log section to see if it gives you more info there.
Currently, I have these packages (Calea, gps,lora, routeros, tr069-client, ups, user-manager) installed on my mikrotik router. I tried online upgrade but the above error appeared, also I tried manual upgrading with downloading 7.11.2 routeros and extra packages and put all of them on files and then restart the mikrotik but again without success.
Again
What does log section indicate ?
Is there an error message to be seen there with more info ?
remove all addon package then upgrade it will work
What do you mean by addon packages?
remove all this (Calea, gps,lora, routeros, tr069-client, ups, user-manager) then update to 7.11.2 except the base package of course (routeros)
I still would like to know what the log shows …
Shortcut:
Just drop the upgrade routeros npk on files. No additional packages.
Reboot.
If that doesn’t work, use loloski’s suggestion:
go to packages and mark all additional packages for removal.
Reboot.
You should end up only having routeros, still old version.
Then upgrade
Then add additional packages again (but since you use lora, it might be possible you only need to add iot and not lora anymore).
Ok thank you all. I will give it a try and will let you know the result.
