I can not upload files to the directory with Doude
icon plus no at all
icon plus no at all
You must use winbox for that, the client do not upload anything
The same is not possible. Here is the error when moving the file:
All. The problem is solved. RTFM …
It’s very bad form to post stuff like this and then not say what/where the solution is.
So what/where is it, specifically?
Não consegui a solução, pois já verifiquei na internet e nada de solução.
ATROX can u tell us, how do u solve the problem?
