can on link two lan segments with vwlans
Hi I would like to know if one can bridge 2 wlans by using vwlans.
Basically 1 wlan is pointing one direction and the other is pointing total opposite direction, but I would like to have the ability to play lan with the person on the other segment.
can i create two vlan links and add them to a bridge. Thus enableing one vwlan.
Or is there another simpler way to do this?
Any comments sugestions are welcome.
