Can only access SXT 5HPnD radios via webfig
I have 2 newly installed SXT 5HPnD radios that, until recently, I had no problem logging into them via WinBox. Something changed and now I can only access them via webfig.
WinBox simply displays: “ERROR: could not connect”. There is nothing in the log because I’m not even getting that far.
Aside from WinBox access, they’re working perfectly.
Any insight or suggestions would be much appreciated.
Thanks.
Check firewall and ip-services. You can be blocking the access somehow.
Thank you Jarda. For some reason, Services had the incorrect ports.
