Can Ping but Can't View Website
I’m starting a new topic because this is different than the last. I have the LAN side setup with 10. addressing and can ping the gateway at 10.10.1.1. I can also resolve host names using a DNS server on the WAN side at 192.169.1.14. The WAN side address is 192.168.1.220. I can ping external web addresses like google.com, but I cannot open the websites.
My export is
# feb/05/2026 11:12:39 by RouterOS 6.49.19
# software id = 4462-Q26S
# model = RB750Gr3
# serial number =
set [ find default-name=ether2 ] name="LAN 2"
set [ find default-name=ether3 ] name=LAN3
set [ find default-name=ether1 ] name=WAN-Ether1
add name=WAN
add name=LAN
add name=PoolDHCP ranges=10.10.1.100-10.10.1.254
add address-pool=PoolDHCP disabled=no interface=LAN3 lease-time=1d name=\
    DHCPNew
add comment=defconf disabled=yes interface=WAN-Ether1
/interface detect-internet
set detect-interface-list=WAN
add interface=WAN-Ether1 list=WAN
add interface=LAN3 list=LAN
add address=192.168.1.220 interface=WAN-Ether1 network=192.168.1.0
add address=10.10.1.1 interface=LAN3 network=10.10.1.0
/ip dhcp-client
add comment=defconf interface=WAN-Ether1
add address=10.10.1.0/24 dns-server=192.168.1.14 gateway=10.10.1.1
set servers=192.168.1.14
add check-gateway=ping distance=1 gateway=WAN-Ether1
add distance=1 dst-address=10.10.1.0/24 gateway=LAN3
/system clock
set time-zone-name=America/New_York
/system identity
set name=AWOD1
/system ntp client
set enabled=yes primary-ntp=192.5.41.40 secondary-ntp=192.5.41.41 \
    server-dns-names=192.168.1.14
and my routes are;
# feb/05/2026 11:13:57 by RouterOS 6.49.19
# model = RB750Gr3
# serial number =
The odd internal condition is that I’m using the device to subnet automated machiney to keep the normal business traffic from interfering with the automation equipment.
Not really-really, those are only the static routes (that are already in the configuration ypu posted).
Post the output of:
/ip route print
to show ALL your routes, (the static ones + the dynamic ones) you have.
completly useless
Please read my post in the other thread about setting address under /ip address.
Don't do this:
But instead, do this:
add address=10.10.1.1/24 interface=LAN3 network=10.10.1.0
and remove
Because it would no longer be needed.
With your WAN interface, you currently have both this:
(which probably has the wrong prefix length BTW, it most certainly shouldn't be /32)
and this:
/ip dhcp-client
Please decide whether you have working DHCP client or you have to configure static address for LAN.
  • If you have working DHCP client, then remove this:
    and this:
  • But if your WAN side has no working DHCP server, and you need to configure address by hand, then:
    Remove this:
    /ip dhcp-client
    Change this:
    into this (with /24)
    add address=192.168.1.220/24 interface=WAN-Ether1 network=192.168.1.0
    And replace this manual route
    With this manual route (assuming 192.168.1.1 is you WAN gateway, if not, adjust!):
    add check-gateway=ping distance=1 gateway=192.168.1.1
With your current configuration, if the WAN side has a DHCP server, then you probably are having ECMP routes for WAN, with one of the two routes being obviously wrong (the one you added manually).
Why interface and not the IP?
@CGGXANNX Ok, now is useless to continue :wink:
Combatting AI games?
FALSE.
@CGGXANNX had already warned the user about putting /24 in "/ip address" in the other post, but he doesn't care...
So let him do it hAImself...
WAN side has DHCP, but I want it to be a fixed IP so we can route to it. I removed the old DHCP client that must have been left from paying around.
Not that I didn’t care, it’s that I’m overwhelmed, hahaha. This is one of those things that is important and not urgent, so I have not yet had time to understand CSGXANNX’s helpful reply.
How do I save the /ip route print to a file? I tried /ip route print export file-filename but it didn’t like it.
[admin@AWOD1] > /ip route print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme,
 0 A S  0.0.0.0/0                          WAN-Ether1                1
 1 A S  10.10.1.0/24                       LAN3                      1
 2 ADC  10.10.1.0/32       10.10.1.1       LAN3                      0
 3 ADC  192.168.1.0/32     192.168.1.220   WAN-Ether1                0
I think I have the recommondations entered.
[admin@AWOD1] > /export
# feb/05/2026 15:04:01 by RouterOS 6.49.19
# model = RB750Gr3
# serial number =
add name=WAN
add name=LAN
add address-pool=PoolDHCP disabled=no interface=LAN3 lease-time=1d name=DHCPNew
/system clock
/system identity
set name=AWOD1
/system ntp client
set enabled=yes primary-ntp=192.5.41.40 secondary-ntp=192.5.41.41 server-dns-names=192.168.1.14
and
 1 ADC  10.10.1.0/24       10.10.1.1       LAN3                      0
 2 ADC  192.168.1.0/24     192.168.1.220   WAN-Ether1                0
I can resolve host names but cannot get ping responses.
Which IP address has the gateway (the device/router on the other end of the cable connected to port WAN-ether1)?
192.168.1.1?
Try changing:
add check-gateway=ping distance=1 gateway=WAN-ether1 192.168.1.1
No! You have not! Look at the default route. It still has WAN-Ether1 as gateway, because you added it like this:
Please read what I wrote above:
The interface is an ethernet interface (not point-to-point like PPPoE for example), you can't have the default route specifying only the interface as gateway. Because the router will then use ARP even when you try to go to 8.8.8.8 for example, and that obviously won't work.
You have to set the gateway to the IP address of the WAN router. In the example above it was assumed that 192.168.1.1 is the address of this router. If it differs, then adjust that value in the command.
I’m sorry guys, that was stupid of me. I got confused about who’s gateway to enter.
Thanks to all of you, it works!
No problem, you are learning, and mistakes are cheap and plentiful. However attempt to be more disciplined especially adhering to the advice given, it gets rid of the obvious errors allowing us to hone in on the rest.
Always true: "The greatest teacher, failure is." (c) Yoda
