Can ping VPN from ROS but not from wifi client, why?
Hello!
I’ve made a config for routing wifi traffic through wireguard vpn. It doesn’t work. I want to understand why. Sadly the config is a bit convoluted, however I only want to understand /ip/route part, perhaps someone could explain without digging too deep.
I want wifi clients’ traffic to run through wg1 interface. The interface itself works, I can ping from ROS, ping comes up on wireguard server. But when I ping from wifi client it doesn’t work. Here’s 6 cases:
  1. from mikrotik ping 10.10.0.3 (vpn client address) – ok
  2. from mikrotik ping 10.10.0.1 (vpn server address) – ok
  3. from mikrotik ping anything-on-internet – ok
  4. from wifi client ping 10.10.0.3 (vpn client address) – ok
  5. from wifi client ping 10.10.0.1 (vpn server address) – timeout, nothing on VPN server
  6. from wifi client ping anything-on-internet – timeout, nothing on VPN server
My question is, why in cases 5 and 6 traffic gets dropped? I thought adding default route 0 As 0.0.0.0/0 wg1 2 should do the trick.
addresses:
[admin@MikroTik] > ip address print
Columns: ADDRESS, NETWORK, INTERFACE
# ADDRESS           NETWORK      INTERFACE
0 192.168.1.200/24  192.168.1.0  bridge
1 10.10.0.3/24      10.10.0.0    wg1
routes:
[admin@MikroTik] > ip route print
Flags: D - DYNAMIC; A - ACTIVE; c, s, y - COPY
Columns: DST-ADDRESS, GATEWAY, DISTANCE
#     DST-ADDRESS     GATEWAY        DISTANCE
1  As <wg-inet-public-ip>/32  192.168.1.254         1
  DAc 10.10.0.0/24    wg1                   0
  DAc 192.168.1.0/24  bridge                0
About network:
  • My LAN gateway (G) is 192.168.1.254/24, not a mikrotik.
  • My mikrotik (M) is 951G-2HnD current firmware 7.2.3
  • M is connected to LAN in full switch mode, DHCP client&server disabled.
  • M has ip 192.168.1.200 statically assigned to it to avoid using G’s DHCP.
  • VPN server is on remote linux machine, it’s VPN address is 10.10.0.1/24.
  • VPN client is on M, interface wg1, it’s address is 10.10.0.3/24.
  • Wifi client is an android phone, configured manually, ip 192.168.1.201, gateway 192.168.1.200 (M), DNS 8.8.8.8, again to avoid G’s DHCP.
I’ve added wg1 to WAN list and enabled masquerade and now it works. Though I have double masquerade now, on MT and on wg server, sluggish.
huh, not very helpful it was,
moderator, kill the thread please
Have you solved your issue.
Also your convoluted explanation sorely needed a diagram.
Everything happens inside MT, what kind of diagram do you expect, of single box? The question was about internal MT routing, I may be provided excessive details, but these questions are hard to ask. If you provide no info you get yelled at because “RTFM and not enough info”. If you provide a lot of info question gets ignored for looking too complicated. I yearn for the day when I figure out how to properly interact with forums.
Never mind though, that config is gone, I have reset the router and starting anew. I solved my issue in a broken and hacky way, I want to make a clean config. I will ask another question, this thread won’t benefit anyone, so it’d better be removed.
https://forum.mikrotik.com/viewtopic.php?p=908118
