Can POE be "daisy chained" ?
Would it be possible to feed a CRS112-8P-4S-IN with POE power from a CSS610-8P-2S+IN, and then attach other POE devices to the CRS112-8P-4S-IN ?
Yes and no, mostly no.
CSS610-8P-2S+IN
PoE-out
Details
PoE-out ports Ether1-Ether8
PoE out 802.3af/at
Max out per port output (input 18-30 V) 1000 mA
Max out per port output (input 30-57 V) 625 mA
Total output power 140
CRS112-8P-4S-IN
Powering
Details
Number of DC inputs 2 (DC jack)
DC jack input Voltage 18-28 V / 48-57 V
Max power consumption 160 W
Max power consumption without attachments 10 W
Cooling type Passive
The CRS112 has no PoE in, so you would need a splitter.
But the CRS610 can output MAX (on one port) either 1A@30V=30W or 0.625A@57V=35.625.
The CRS112 will want some 10W, so you will have at most 20-25W available to power other devices, so, at the most, a couple access points or anyway low power 802.3af devices, provided that the cables between these devices are not too long and good quality, as some power/voltage will be reduced further.
