Can PowerBoxPro Operate in -48VDC environment
Can PowerBoxPro Operate in -48VDC environment? We current cut the AC adapter cord and provide + to + and - to - in a non-ground referenced 48VDC environment. We don’t attach the ground.
what happens when you run a shielded (or not) cable to a tower with a radio on it (or anotehr customers router) and the other radios on the tower arent the same power setup. make sure you use an isolated ground somehow.
