Since recent, I am on FTTH, 2.5Gbps symmetrical. Unfortunate with pppoe.
Using ISP modem/wifi/combo box, Huawei stuff, I can easily go to 2.3Gbps.
Removing ISP modem, and using RB5009, upload barely goes to 270-390 Mbps, with not much CPU load.
Is that it, is Huawei more capable than Mikrotik RB5009?
WAN is SFP+ port and VLAN is ether1.
I started with netinstall 7.22.1 including firmware, and built manually on that. No fix done to ether1 to solve the 2.5Gbps issue.
Any suggestions? I hate getting rid of the RB5009, but slowly thinking to go all the way other brands.
# 2026-04-18 19:43:10 by RouterOS 7.22.1
# model = RB5009UPr+S+
# serial number =
add frame-types=admit-only-vlan-tagged name=bridge1 vlan-filtering=yes
/interface vlan
add interface=bridge1 name=CCTV vlan-id=40
add interface=bridge1 name=Guest vlan-id=60
add interface=bridge1 name=IPTV vlan-id=50
add interface=bridge1 name=Internal vlan-id=10
add interface=bridge1 name=IoT vlan-id=20
add interface=bridge1 name=Management vlan-id=80
add interface=bridge1 name=SNLLR vlan-id=6
add interface=bridge1 name=Work vlan-id=30
add name=WAN
add name=VLAN
add name=TRUSTED
add name=Internal ranges=192.168.10.100-192.168.10.200
add name=IoT ranges=192.168.20.100-192.168.20.200
add name=Work ranges=192.168.30.100-192.168.30.200
add name=CCTV ranges=192.168.40.100-192.168.40.200
add name=IPTV ranges=192.168.50.100-192.168.50.200
add name=Guest ranges=192.168.60.100-192.168.60.200
add name=Management ranges=192.168.80.100-192.168.80.200
add address-pool=Internal interface=Internal lease-time=3d name=Internal
add address-pool=IoT interface=IoT lease-time=3d name=IoT
add address-pool=Work interface=Work lease-time=3d name=Work
add address-pool=CCTV interface=CCTV lease-time=3d name=CCTV
add address-pool=IPTV interface=IPTV lease-time=3d name=IPTV
add address-pool=Guest interface=Guest lease-time=3d name=Guest
add address-pool=Management interface=Management lease-time=3d name=
Management
/interface pppoe-client
add add-default-route=yes disabled=no interface=SNLLR keepalive-timeout=30
name=SNLLLR_pppoe password=trined profile=default-encryption
use-peer-dns=yes user=trined@trined.nl
add bridge=bridge1 frame-types=admit-only-vlan-tagged interface=sfp-sfpplus1
pvid=6
add bridge=bridge1 frame-types=admit-only-vlan-tagged interface=ether1
set discover-interface-list=TRUSTED
/interface bridge vlan
add bridge=bridge1 tagged=bridge1,sfp-sfpplus1,ether1 vlan-ids=
6,10,20,30,40,50,60,80
add interface=Internal list=VLAN
add interface=IoT list=VLAN
add interface=Work list=VLAN
add interface=CCTV list=VLAN
add interface=IPTV list=VLAN
add interface=Guest list=VLAN
add interface=Management list=VLAN
add interface=Internal list=TRUSTED
add interface=Management list=TRUSTED
add interface=ether7 list=TRUSTED
add interface=SNLLLR_pppoe list=WAN
add address=192.168.10.1/24 interface=Internal network=192.168.10.0
add address=192.168.20.1/24 interface=IoT network=192.168.20.0
add address=192.168.30.1/24 interface=Work network=192.168.30.0
add address=192.168.40.1/24 interface=CCTV network=192.168.40.0
add address=192.168.50.1/24 interface=IPTV network=192.168.50.0
add address=192.168.60.1/24 interface=Guest network=192.168.60.0
add address=192.168.80.1/24 interface=Management network=192.168.80.0
add address=192.168.10.0/24 dns-server=192.168.10.1 gateway=192.168.10.1
add address=192.168.20.0/24 dns-server=192.168.20.1 gateway=192.168.20.1
add address=192.168.30.0/24 dns-server=192.168.30.1 gateway=192.168.30.1
add address=192.168.40.0/24 dns-server=192.168.40.1 gateway=192.168.40.1
add address=192.168.50.0/24 dns-server=192.168.50.1 gateway=192.168.50.1
add address=192.168.60.0/24 dns-server=192.168.60.1 gateway=192.168.60.1
add address=192.168.80.0/24 dns-server=192.168.80.1 gateway=192.168.80.1
set allow-remote-requests=yes cache-size=150000KiB
/ip dns adlist
add ssl-verify=no url="https://cdn.jsdelivr.net/gh/tarampampam/mikrotik-hosts-\
parser@master/.hosts/basic.txt"
add ssl-verify=no url="https://raw.githubusercontent.com/What-Zit-Tooya/Ad-Blo\
ck/main/Main-Blocklist/Ad-Block-HOSTS.txt"
add ssl-verify=no url="https://justdomains.github.io/blocklists/lists/easypriv\
acy-justdomains.txt"
https://justdomains.github.io/blocklists/lists/easylist-justdomains.txt
https://justdomains.github.io/blocklists/lists/nocoin-justdomains.txt
add ssl-verify=no url=https://adaway.org/hosts.txt
add ssl-verify=no url="https://raw.githubusercontent.com/hagezi/dns-blocklists\
/main/hosts/native.winoffice.txt"
add ssl-verify=no url="https://raw.githubusercontent.com/crazy-max/WindowsSpyB\
locker/master/data/hosts/spy.txt"
add ssl-verify=no url="https://cdn.jsdelivr.net/gh/hagezi/dns-blocklists@lates\
t/hosts/ultimate.txt"
https://justdomains.github.io/blocklists/lists/adguarddns-justdomains.txt
https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts
add ssl-verify=no url="https://raw.githubusercontent.com/r0xd4n3t/pihole-adblo\
ck-lists/main/pihole_adlists.txt"
/ip dns static
add address=192.168.10.1 name=mylocal.ntp.server type=A
/ip firewall address-list
add address=192.168.40.0/24 list=Common-Destination
add address=192.168.10.8 list=Printers
add address=192.168.10.0/24 list=to_CCTV
add address=192.168.10.1 list=DNS_Servers
add address=192.168.20.1 list=DNS_Servers
add address=192.168.30.1 list=DNS_Servers
add address=192.168.40.1 list=DNS_Servers
add address=192.168.50.1 list=DNS_Servers
add address=192.168.60.1 list=DNS_Servers
add address=192.168.80.0/24 list=Authorized
add address=192.168.80.1 list=DNS_Servers
add address=192.168.10.0/24 list=Authorized
add address=192.168.80.0/24 list=to_CCTV
add action=accept chain=input comment="Allow established, related, untracked"
add action=drop chain=input comment="drop invalid" connection-state=invalid
add action=accept chain=input comment="accept icmp" in-interface-list=TRUSTED
protocol=icmp src-address-list=""
add action=accept chain=input comment="admin access" in-interface-list=
TRUSTED src-address-list=Authorized
add action=accept chain=input comment="accept internal dns requests"
dst-port=53 in-interface-list=VLAN protocol=tcp
dst-port=53 in-interface-list=VLAN protocol=udp
add action=drop chain=input comment="drop all else"
add action=fasttrack-connection chain=forward comment=fasttrack
connection-mark=no-mark connection-state=established,related
"Allow established, related, untracked" connection-state=
add action=drop chain=forward comment="drop invalid" connection-state=invalid
add action=accept chain=forward comment="Internal LAN to CCTV"
dst-address-list=Common-Destination src-address-list=to_CCTV
add action=accept chain=forward comment="Work Devices to Printer"
dst-address-list=Printers in-interface=Work
add action=accept chain=forward comment="internet traffic but CCTV"
in-interface=!CCTV in-interface-list=VLAN out-interface-list=WAN
add action=drop chain=forward comment="drop all from WAN not DSTNATed"
connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=drop chain=forward comment="drop all else"
add action=dst-nat chain=dstnat dst-address-list=!DNS_Servers dst-port=53
protocol=udp src-address-list=!DNS_Servers to-addresses=192.168.10.1
protocol=tcp src-address-list=!DNS_Servers to-addresses=192.168.10.1
/ip service
set ftp disabled=yes
set ssh disabled=yes
set telnet disabled=yes
set reverse-proxy disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ip service webserver
set acme-plain=no crl-plain=no graphs-plain=no graphs-secure=no index-plain=
no index-secure=no rest-plain=no rest-secure=no scep-plain=no
webfig-plain=no webfig-secure=no
/ipv6 dhcp-client
add custom-iana-id=0 custom-iapd-id=0 default-route-tables=main interface=
SNLLLR_pppoe pool-name=ipv6_pool pool-prefix-length=64 request=prefix
/ipv6 firewall address-list
/ipv6 firewall filter
"defconf: accept established,related,untracked" connection-state=
add action=drop chain=input comment="defconf: drop invalid" connection-state=
invalid
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute"
dst-port=33434-33534 protocol=udp
"defconf: accept DHCPv6-Client prefix delegation" dst-port=546 protocol=
udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500
protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=
ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=
ipsec-esp
"defconf: drop everything else not coming from VLAN" in-interface-list=
!VLAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack6"
add action=drop chain=forward comment="defconf: drop invalid"
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1"
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=
icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=
500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=
ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=
ipsec-esp
!VLAN
/ipv6 nd
set \[ find default=yes \] disabled=yes hop-limit=64
managed-address-configuration=yes other-configuration=yes ra-preference=
low reachable-time=5m
add advertise-dns=yes interface=Internal other-configuration=yes
ra-preference=high reachable-time=5m
add advertise-dns=yes interface=Work other-configuration=yes ra-preference=
add advertise-dns=yes interface=IoT other-configuration=yes ra-preference=
add advertise-dns=yes interface=IPTV other-configuration=yes ra-preference=
add advertise-dns=yes interface=Guest other-configuration=yes ra-preference=
add advertise-dns=yes interface=SNLLLR_pppoe ra-lifetime=none ra-preference=
/system clock
set time-zone-name=Europe/Amsterdam
/system identity
set name=SNLLR
/system ntp client
set enabled=yes
/system ntp server
set broadcast=yes enabled=yes manycast=yes multicast=yes
/system ntp client servers
add address=0.nl.pool.ntp.org
add address=1.nl.pool.ntp.org
add address=2.nl.pool.ntp.org
add address=3.nl.pool.ntp.org
/tool mac-server mac-winbox
set allowed-interface-list=TRUSTED
/tool romon
set enabled=yes
