Can it be hotspot client and how???
Sure it can. But it can’t pass the hotspot login, except if you define its MAC or IP address as “passthrough” in the hotspot parameters
you can log into the hotspot from any windows computer that is behind the router
Yes ? But how?
Bridge wont work
DHCP client, DHCP server, NAT wont work
What’s third option ?
Thank You
both of these should work. what is the result when you try a webpage from the LAN?
nothing happens. On smartphone or laptop it opens hotspot login, but via MT it just says “No internet connection”. I tried closing browser and re-opening but nothing is there.
I use station wireless mode, it connects
I put address x.x.x.x/24 to ethernet port
I setup DHCP on that port
I put NAT, out-interface wlan, action masq
I set DHCP client on wlan
Am I missing something ?
