Can RouterOS do what DD-WRT can?
Universal Wireless Repeater:
Universal Wireless Repeater appliance: a device that you can place anywhere and it will wirelessly repeat the strongest signal, onto another wireless network (with or without security). This functionality is also known as Wireless Client Bridge, or Range Expander. Unlike WDS, once you have this appliance setup, it will work with any open network.
Architecturally the repeater connects to another wireless router as a client, getting a single IP address via DHCP. Effectively the SSID network it connects to becomes your ISP. Therefore you (the client) will operate in your own IP address space, which is different from address space the repeater connects to.
For example:
In a given neighborhood, there are 3 open access wireless networks, jojo, linksys and internetmad. The repeater automatically receives an IP address from jojo. Let’s say jojo is using 192.168.1.0/24, and your DDWRT router receives the address 192.168.1.139. The repeater is configured to use 172.16.100.0/24. From your laptop, you associate with the SSID “repeater” and you receive the address 172.16.101.100 via DHCP. As far as your laptop is concerned you are talking to repeater. As far as repeater is concerned, its gateway is “jojo” and jojo probably has another gateway via cable modem or DSL.
You may use security (WEP, WPA, etc) in repeater mode. An example application of this would be to make the repeated network private (for your use only).
more at: > http://www.dd-wrt.com/wiki/index.php/Universal_Wireless_Repeater
Can above be done under RoutersOS lvl4?
regards,
Michael
you can do much more, not only that, but this is not going to be as easy as filling a simple web form :slight_smile:
That’s good to hear. I searched high and low and all posters seemed to suggest to use WDS.
Have you done it yourself?
regards,
Michael
