Hi guys, Can I run ospf on CRS326-24G-2S+RM. I want to use it as a layer 3 Distribution Switch in my network. Thanks.
Yes you can. With RouterOS only though.
Hi, elbob2002. Do you mean I can run ospf in CRS326-24G-2S+RM only booted with RouterOS.
OSPF is a routing protocol. Requires a router. When run under SwitchOS, the CRS326 is functioning as a switch - not a router.
also all routing is done in CPU - CPU’s are quite limited in the switches. You may not get much data routed on a switch.
Hiya..
first of all let me thank your for your comment as i having problemas setting up OSFP in point to point mode on 2 devices via SFP+ , because i was using a CRSXXX in the middle running SwitchOS mode.. now i know why OSFP is not running.. thanks alot.
