Guys,
Would like to ask if anyone of you have tested using SextantG-5HnD for 20KM point-to-point connection?
If yes, what is the bandwidth?
Kindly share it.
Guys,
Kindly share it.
won’t work, for a reliable connection you need a higher gain antenna
You should use some parabolic dual pol. antenna (Jirous/CyberBajt). SEXTANT has too weak antenna. If you like panels use http://www.wireless-instruments.com/en/produkty/15/45/antennas-5ghz/mimo/directional/wibox-pa-m5-24hv.html, we used them for two point-to-point links.
but.. yes… 20km. you should be able (if not to much noice) to get the same speed as your Ethernet port.
I have some 20km SXT-G links. Running like a charm (and 3db weaker antenna, and no high power)
Guys, thanks for the input. ![]()
We are just looking at 50Mbps estimated bandwidth.
Samsung172, may I know the bandwidth of your tested 20km SXT-G links?
And, others who have tested SEXTANTG 20KM point-to-point, please share some inputs, including the bandwidth that you get.
Thanks a lot
About 50Mb/s TCP.
