Can someone help identify this router..
I’ve looked everywhere but dont seem to find documentation for this. Is the model simply RB750 ? RB750GL ?
Would like to know if ports are 100/1000
[admin@MikroTik-01] > system resource print
uptime: 13m
version: 6.44.1 (stable)
build-time: Mar/13/2019 08:38:51
free-memory: 42.4MiB
total-memory: 64.0MiB
cpu: MIPS 24Kc V7.4
cpu-count: 1
cpu-frequency: 400MHz
cpu-load: 2%
free-hdd-space: 108.8MiB
total-hdd-space: 128.0MiB
write-sect-since-reboot: 97
write-sect-total: 78235
bad-blocks: 0%
architecture-name: mipsbe
board-name: RB750
platform: MikroTik
[admin@MikroTik-01] > system routerboard print
routerboard: yes
model: 750
serial-number: 467704CDB466
firmware-type: ar7240
factory-firmware: 3.17
current-firmware: 6.44.1
upgrade-firmware: 6.44.1
Looks like RB750
Can you link any documentation for it, specs ? If you search for RB750 you find only newer models
Hello
Don’t you have physical access?
The sticker under should have all the details.
Regards,
Sent from my cell phone. Sorry for the errors.
At any rate, once you find out the model, go on routerboard.com, search for end of life models and the specs should be there.
Behind it says RouterBoard 750, but not much else. The ports are 100Mbps, so I guess it is the RB750 (no letters). It also has 64MB RAM, MIPS 24Kc V7.4 @400MHz CPU, and 128MB HDD. Board Name is RB750.
I searched in https://mikrotik.com/product/ using the ‘archived’ filter, but I dont see it
https://www.roc-noc.com/mikrotik/routerboard/rb750.html
RouterBOARD 750 with AR7240 CPU, 32MB RAM (?), 5 LAN ports, RouterOS L4, plastic case, power supply, in a retail box.
Ports are 10/100 not 10/100/1000
Mystery solved, thanks.
(Mine has 64MB RAM and 128MB HDD, but the port speed shouldnt change)
