I want to know why the firewall rules I have setup to drop brute forcers is not working. It’s not adding the source addresses to any of the lists I specify. I’m betting its something having to do with the way I have nat setup for the port. Here is an export (all public ip’s were renamed to protect the innocent
ewall> export
/ip firewall address-list
add address=mbffj.lawl.wtf.omg! disabled=no list=rdp_blacklist
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s
tcp-close-wait-timeout=10s tcp-established-timeout=1d
tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s
tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no
tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=drop chain=input comment=“drop ftp brute forcers” disabled=no
dst-port=333 protocol=tcp src-address-list=ftp_blacklist
add action=accept chain=output content=“530 Login” disabled=no dst-limit=
1/1m,9,dst-address/1m protocol=tcp
add action=add-dst-to-address-list address-list=ftp_blacklist
address-list-timeout=3h chain=output content=“530 Login” disabled=no
protocol=tcp
add action=drop chain=input comment=“drop ssh brute forcers” disabled=no
dst-port=22 protocol=tcp src-address-list=ssh_blacklist
add action=add-src-to-address-list address-list=ssh_blacklist
address-list-timeout=1w3d chain=input connection-state=new disabled=no
dst-port=22 protocol=tcp src-address-list=ssh_stage3
add action=add-src-to-address-list address-list=ssh_stage3
address-list-timeout=1m chain=input connection-state=new disabled=no
dst-port=22 protocol=tcp src-address-list=ssh_stage2
add action=add-src-to-address-list address-list=ssh_stage2
dst-port=22 protocol=tcp src-address-list=ssh_stage1
add action=add-src-to-address-list address-list=ssh_stage1
add action=drop chain=virus comment=“Drop Spammer” disabled=no dst-port=25
protocol=tcp src-address-list=spammer
add action=add-src-to-address-list address-list=spammer address-list-timeout=
1d chain=virus comment=“add to spammer list” connection-limit=30,32
disabled=no dst-port=25 limit=50,5 protocol=tcp
add action=add-src-to-address-list address-list=“port scanners”
address-list-timeout=2w chain=input comment="Port scanners to list "
disabled=no protocol=tcp psd=21,3s,3,1
address-list-timeout=2w chain=input comment=“NMAP FIN Stealth scan”
disabled=no protocol=tcp tcp-flags=fin,!syn,!rst,!psh,!ack,!urg
address-list-timeout=2w chain=input comment=“SYN/FIN scan” disabled=no
protocol=tcp tcp-flags=fin,syn
address-list-timeout=2w chain=input comment=“SYN/RST scan” disabled=no
protocol=tcp tcp-flags=syn,rst
address-list-timeout=2w chain=input comment=“FIN/PSH/URG scan” disabled=
no protocol=tcp tcp-flags=fin,psh,urg,!syn,!rst,!ack
address-list-timeout=2w chain=input comment=“ALL/ALL scan” disabled=no
protocol=tcp tcp-flags=fin,syn,rst,psh,ack,urg
address-list-timeout=2w chain=input comment=“NMAP NULL scan” disabled=no
protocol=tcp tcp-flags=!fin,!syn,!rst,!psh,!ack,!urg
add action=drop chain=input comment=“dropping port scanners” disabled=no
src-address-list=“port scanners”
add action=drop chain=input comment=“Drop brute force rdpers” disabled=no
dst-port=3389 protocol=tcp src-address-list=rdp_blacklist
add action=add-src-to-address-list address-list=rdp_stage1
address-list-timeout=10m chain=input disabled=no dst-port=3389 protocol=
tcp
add action=add-src-to-address-list address-list=rdp_stage2
address-list-timeout=10m chain=input connection-state=new disabled=no
dst-port=3389 protocol=tcp src-address-list=rdp_stage1
add action=add-src-to-address-list address-list=rdp_stage3
dst-port=3389 protocol=tcp src-address-list=rdp_stage2
add action=add-src-to-address-list address-list=rdp_blacklist
dst-port=3389 protocol=tcp src-address-list=rdp_stage3
add action=masquerade chain=srcnat comment=“masquerade hotspot network”
disabled=no src-address=192.168.16.0/24
add action=dst-nat chain=dstnat disabled=no dst-address=bs.bs.bs.bs
dst-port=21 protocol=tcp to-addresses=192.168.16.2
dst-port=443 protocol=tcp to-addresses=192.168.16.2
dst-port=80 protocol=tcp to-addresses=192.168.16.2
dst-port=3389 protocol=tcp to-addresses=192.168.16.2
dst-port=333 protocol=tcp to-addresses=192.168.16.2
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=75
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061
set pptp disabled=no
Thanks guys!
