In a 2-router network, a “demo” router (RouterBOARD 750 r2) is behind the Internet gateway (RouterBOARD 952Ui-5ac2nD), A PC on the g/w LAN (..88.) can SSH to any host on either router and to the routers themselves. Two instances of WinBox on the PC manage the routers. The link between the routers is static routed as a 10. subnet.
Static routing uses dst-nat in both routers. Attempts to SSH from the Internet (eth1) result in either a timeout (usually) or a peer reset of the connection (if connecting via VPN). I have been thinking that the same firewall rules govern both paths of access so both should work–but they behave differently. The exported config of the g/w is:
# apr/21/2024 11:45:07 by RouterOS 6.49.10
# software id = 52AR-8NVD
# model = RouterBOARD 952Ui-5ac2nD
# serial number = 71AF0xxx
/interface wireless
xxx
add admin-mac=B8:69:xxx auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=xxx
add name=pool10 ranges=10.10.10.10-10.10.10.19
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
add address-pool=pool10 disabled=no interface=ether3 name=server10
add bridge=bridge comment=defconf disabled=yes interface=ether3
add bridge=bridge comment=defconf interface=wlan2
set tcp-syn-received-timeout=10s tcp-syn-sent-timeout=10s
/ip settings
set allow-fast-path=no
add interface=ether3 list=LAN
192.168.88.0
add address=10.10.10.1/24 interface=ether3 network=10.10.10.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
/ip dhcp-server lease
add address=192.168.88.245 mac-address=1C:6F:xxx server=defconf
add address=192.168.88.239 client-id=1:14:cb:xxx mac-address=\
14:CB:19:xxx server=defconf
add address=10.10.10.10 client-id=1:b8:69::xxx mac-address=\
B8:69:F4:xxx server=server10
add address=192.168.88.228 mac-address=B0:A4:xxx server=defconf
add address=192.168.88.249 client-id=1:14::xxx mac-address=\
14:4F::xxx server=defconf
add address=10.10.10.0/24 gateway=10.10.10.10 netmask=24
192.168.88.1
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input comment="defconf: accept dstnat" \
connection-nat-state=dstnat in-interface=all-ethernet
add action=drop chain=input comment="drop icmp from eth1" disabled=yes \
in-interface=ether1 protocol=icmp
invalid
add action=drop chain=input comment="defconf: drop telnet 23 from wan" \
dst-port=23 in-interface=ether1 protocol=tcp
add action=drop chain=input comment="defconf: drop ssh 22 from wan" dst-port=\
22 in-interface=ether1 protocol=tcp
established,related,untracked
add action=accept chain=input comment="accept tcp" disabled=yes in-interface=\
all-ethernet protocol=tcp
in-interface-list=!LAN
add action=drop chain=forward comment="defconf: drop sshy 22 from wan" \
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=established,related disabled=yes
add action=accept chain=forward comment=" accept new " connection-state=new \
disabled=yes
connection-state=invalid
add action=accept chain=output connection-nat-state=dstnat dst-port=22 \
protocol=tcp
add action=dst-nat chain=dstnat dst-port=xxxxx02 protocol=tcp to-addresses=\
192.168.55.247 to-ports=xxx2
add action=dst-nat chain=dstnat dst-port=xxxxx03 protocol=tcp to-addresses=\
add action=dst-nat chain=dstnat dst-port=xxxxx49 protocol=tcp to-addresses=\
192.168.55.249 to-ports=xxx9
add action=dst-nat chain=dstnat dst-port=xxxxx50 in-interface=all-ethernet \
protocol=tcp to-addresses=192.168.55.228 to-ports=22
add action=dst-nat chain=dstnat dst-port=xxxxx80 in-interface=all-ethernet \
protocol=tcp to-addresses=192.168.88.1 to-ports=80
add action=dst-nat chain=dstnat dst-port=xxxxx30 protocol=tcp to-addresses=\
192.168.88.1 to-ports=22
add distance=1 dst-address=192.168.55.0/24 gateway=10.10.10.10
/ip service
set ssh address=0.0.0.0/0
set api disabled=yes
set api-ssl disabled=yes
/system clock
set time-zone-name=America/New_York
/system identity
set name=MikroTik-gw
/tool mac-server
/tool mac-server mac-winbox
/tool sniffer
set filter-interface=bridge filter-operator-between-entries=and filter-port=\
ssh
I suspect the problem results from my limited understanding of firewall rules. Hope you can spot something wrong and make a suggestion. Thanks in advance.
