What is wrong with this setup? I do get an IP address and the system time is updated so I know have some contact with the outside world but I cant surf the web?
# feb/06/2013 15:31:33 by RouterOS 5.22
# software id = TQBA-3U8S
set 2 name=WAN
set 3 name=LAN
set 4 master-port=LAN name=LAN-slave1
set 5 master-port=LAN name=LAN-slave2
set 6 master-port=LAN name=LAN-slave3
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m
add name=DHCP-Pool-LAN ranges=192.168.88.20-192.168.88.230
add address-pool=DHCP-Pool-LAN authoritative=yes disabled=no interface=LAN \
lease-time=3h name=DHCP-LAN
add address=192.168.88.1/24 comment="default configuration" interface=WAN
add address=192.168.88.2/24 interface=LAN
add address=192.168.88.3/24 interface=LAN-slave1
add address=192.168.88.4/24 interface=LAN-slave2
add address=192.168.88.5/24 interface=LAN-slave3
add address=192.168.88.6/24 interface=ether6
add address=192.168.88.7/24 interface=ether7
add address=192.168.88.8/24 interface=ether8
add address=192.168.88.9/24 interface=ether9
add address=192.168.88.10/24 interface=ether10
add address=192.168.88.11/24 interface=ether11
add address=192.168.88.12/24 interface=ether12
add address=192.168.88.13/24 interface=ether13
/ip dhcp-client
add comment="Dynamic IP" disabled=no interface=WAN
add address=192.168.88.0/24 comment=LAN dns-server=8.8.8.8 gateway=\
192.168.88.1
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.88.1 name=router
add action=masquerade chain=srcnat comment="default NAT" out-interface=WAN \
to-addresses=0.0.0.0
/system ntp client
set enabled=yes mode=unicast primary-ntp=192.36.144.23 secondary-ntp=\
193.10.7.246
cbrown
February 6, 2013, 4:09pm
2
What are you trying to do with your IP addresses?
Backard:
set 2 name=WAN
set 3 name=LAN
/ip dhcp-client
192.168.88.1
/ip dns static
/system ntp client
193.10.7.246
change
/ip dhcp-client
to
/ip dhcp-client
add comment="Dynamic IP" disabled=no interface=WAN add-default-route=yes
I thought every port needed an IP?
No, the ports can be slaved or bridged - so if every device is on one network, your internal ports only need one address. The wan port would also need one as well.
cbrown
February 6, 2013, 4:17pm
6
No, Your 192.168.88.1/24 need to be on your LAN interface not your WAN.
I think your best bet would be to use the Quick Set feature at the top of the Winbox menu.
There is no Quick set so I need to do it manually.
192.168.88.1 is default on ether 1 so when I set ether to that address I got same addresses on both ports? How can I get rid of it on port 1?
# feb/06/2013 16:26:17 by RouterOS 5.22
set 2 name=WAN
set 3 name=LAN
add address=192.168.88.1/24 interface=LAN
/ip dhcp-client
192.168.88.1
/ip dns static
/system ntp client
193.10.7.246
Well finally it works. Thanks!
I set the WAN on ether 13.
