Hi Folks,
i have some troubles to get routing to work on my RB2011L Mikrotik with OS6.48 !
For explanation please refer to the Infrastructure Overview pic attachet to this post. The Problem is, that I am able to ping and connect to clients in local LAN Segment 192.168.1.0/24 from WLAN 192.168.2.0/24 but I am not able to ping or connect to Clients from local LAN to WLAN.
The routing and address settings are look like this:
[admin@GWRouter] > /ip address print
ADDRESS NETWORK INTERFACE
0 ;;; default configuration
192.168.88.1/24 192.168.88.0 bridge-local
1 ;;; Local LAN
192.168.1.1/24 192.168.1.0 ether4
2 D 77.xx.xx.xx/24 77.xx.xx.x ether1-gateway
3 X ;;; Uplink Asus Wlan
192.168.2.2/24 192.168.2.0 ether3
[admin@GWRouter] > /ip route print
DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 A S 192.168.2.0/24 192.168.1.64 1 <<< it doesn´t matter if this rout is enabled or not .. it won´t work either
1 ADS 0.0.0.0/0 77.xx.xx.x 1
2 ADC 77.xx.xx.x/24 77.xx.xx.xx ether1-gateway 0
3 ADC 192.168.1.0/24 192.168.1.1 bridge-local 0
4 ADC 192.168.88.0/24 192.168.88.1 bridge-local 0
For a better View I attachet LAN config as well.
Thanks for your Help
Cheers
Thomas
Lan Config.txt (1.27 KB)
