Can the Dude be configured to monitor PPTP locations?
I have several sites that have dynamic IP’s and I manage them via PPTP. I want the Dude to be able to test for availability periodically with PPTP and send an e-mail or page if site is down. Can The Dude do this? I do not see PPTP as a protocol choice.
Thanks,
Jerry Roy
It was discussed before but I don’t think it was resolved.
Either purchase a static IP from the ISP or use the use the “name to address” feature.
A reconnect should resolve the name and update the address…
The 2nd option would only work if your machine registers it’s name with the ISP.
I have all static IP’s but I am a little confused o how to implement. Can you offer more details?
Thanks!
Ok, I got it to connect but can I do this?
Can it connect to one site via pptp, ping a bunch of devices, email if pings don’t work, hang up pptp connection and repeat for site # 2? devices on #2 site might be different (more or less IP’s to monitor)?
TIA for any support
