Can the username be changed in the MikroTik RB112
I have been looking through the online manual looking to see if there is any way I can change the default username from .
Is it possible to edit the username value?
add a new user with all rights, and disable the admin user. /user
Thanks for the help :wink:
i would add, that everything that can be done on RB500 works on RB100 but better - do not that on RB100 due to its limitations (cpu speed and ram amount)
so, no fancy routing protocols, no usermanager etc. etc. it is only CPE.
but everything can be done. :unamused: no difference.
