Can you create xen images on Store?
I would like to create ROS images on the Store. Or allow a virtual machine to access a portion of a secondary disk as a store.
Is this possible? If so, how?
Here is how i have it setup…
ROS 3.22 x86 install with Xen package on a 1GB CF with a CF to IDE adapter.
a secondary SATA 160G disk is installed as well.
I have created another ROS image and would like to install user manager to it this virtual machine and allow it to either run from the sata drive or use PART of the sata drive as a store.
Can I specify just part of the sata drive as a store on the virtual machine?
If this is possible, I would like to create a virtual machine for the virtual manager and one for the DUDE to run independently and possibly create other virtual machine with either user manager or dude on them for customers to potentially use.
Any ideas?
