You need two configurations for each SSID, so a total of four in your case. And you can serve more than one configuration with the same SSID, as long as they are using different bands.
It is interesting that I have 4 CAPs connected to CAPSMAN with create dynamic, only two configs and it automatically created two networks on both my 2.4Ghz and 5Ghz radios. CAPs are in CAP mode, interfaces dynamically created, caps dynamically added. I never specified the 2.4 and 5ghz radios specifically, although.
So, at least in dynamic mode, if you have 2 radios - 2.4 and 5Ghz and you do not specify radio type, then it creates both 2.4 and 5Ghz networks with the same network config. Otherwise, you will need 4 configs. Or if you do not use create dynamic, but create. The drawback is that if you need to specify channels and not using autoselect, it is somewhat more difficult.
Your config is different from mine, although. I created VLANs on a bridge with a interface assigned to it. And then assigned these VLANs to the WLAN config, which then was provisioned.
I also had two configs (office and guest) that were served as master and slave by the provisioning rule. This configured automatically both 2.4 and 5 for office, and created a second virtual interface on each radio for the Guest SSID in slave.
Smartphones never had any issues, but lap tops sometimes could not connect. I think the reason was that the automatic configuration created very large networks or used non standard channels, to which computers might be more sensitive. So I ended up differentiating between 2.4 and 5 in order to configure the channels specifically. Right now this is what seems the most stable :
Strange things. Also faced the same problem. RB750Gr3 Revision4. All clients stay in 2.4Ghz and do not use 5Ghz, although I have many different devices in use, like 4011, 2011, CCR1009 with similar presets of capsman.
Thanx alfred998 , your suggestions helped me with RB750Gr3.
