Can you safe a config with Winbox
Hi all.
I’m looking for 2 information on RB333
a) I setup the config and would like to make a full copy of it, so I can copy this on other RBs and only have to change the IPs, and also use it as a backup. All PWs should stay as I put them on
b) Is it possible as with cisco routers to perform a Show run command, so I see the corrent system?
Thanks,
Chris
a)/system backup load/save
b)/export
Dear all ;
simply go to the left menu , then click on files
click on backup to make a backup file and when it appear on the list click on it and click on copy , wait until copying it to the clipboard and then paste it to your computer for future use .
with best regards
:slight_smile:
And don´t forget to alter your routes and possibly other data that should be different. :slight_smile:
