Canadian contractor
Can we have a Toronto Canada contact to work with us to setup a Web Proxy for each of our 192 Router Boards, so that the students web access can be controlled.
Thank you
Did you find your contractor.
We have already develop a software on Mikrotik system for your specific needs.
www.digicom.ca
Thank you for your note, but I can not see any of the work you have done for the MikroTik Routers.
Please send us a link of one of your projects.
It will be difficult to find someone in Toronto that uses Mikrotik because there are no WISPs in/near Toronto AFAIK.
Are you sure this can’t be done remotely?
If you haven’t found anyone to help you locally yet, try Purepages.ca. They are installing MikroTik products for their cutomers.
