Hello fellow RouterOS users,
I am a noob and now having a problem with newly arrived RBM33G. I have installed one LTE modem and a Wifi module and they both work fine, the problem is that in the ssh console I can ping the gateway and addresses on the Internet without any problem, but not from those devices within bridged LAN,
here’s the config
add name=bridge1
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-a/n l2mtu=1596 mode=ap-bridge name=wifi rx-chains=0,1,2 ssid=\
MikroTik tx-chains=0,1,2 wireless-protocol=802.11
add name=WAN
add name=LAN
/ip hotspot profile
add name=dhcp-pool1 ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp-pool1 disabled=no interface=bridge1 lease-time=1d name=dhcp-server1
/port
set 1 name=usb2
/interface ppp-client
add data-channel=2 dial-on-demand=no disabled=no info-channel=2 name=ppp-out1 port=usb2
add bridge=bridge1 interface=wifi
add interface=ppp-out1 list=WAN
add address=192.168.88.1/24 comment=defconf interface=ether1 network=192.168.88.0
add action=masquerade chain=srcnat out-interface=ppp-out1
/port firmware
set directory=flash
I do not know why the wireless interface’s default name is wlan1, it was renamed to wifi and belongs to bridge1
the route
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme,
# DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 ADS 0.0.0.0/0 ppp-out1 1
1 ADC 10.112.112.143/32 10.24.81.203 ppp-out1 0
2 ADC 192.168.88.0/24 192.168.88.1 bridge1 0
all of them are generated
the firewall
in the ssh console, router can :resolve via masquerade, and ping, but on PC it cannot
