Winbox interface does not allow to add OpenVPN server binding port into bridge, while from command line it is possible:
/interface bridge port add interface=ovpn-in1 bridge=bHome
though after adding port with this command possible, you cannot use this interface in bridge rules - it’s just is not present in the bridge rules list.
It was possible to add OpenVPN server interface into bridge in ROS 4.11.
Was this functionality removed?
Can someone who runs OpenVPN in bridge mode confirm that the problem is not only mine?
Thank you.
PS my server OpenVPN config:
[admin@orion6] > /interface ovpn-server server print
enabled: yes
port: 1194
mode: ethernet
netmask: 24
mac-address: FE:B3:A6:77:B1:7A
max-mtu: 1500
keepalive-timeout: 60
default-profile: ovpn-server-test
certificate: cert1
require-client-certificate: yes
auth: sha1
cipher: aes256
