Hi!
I’m trying to harness Huawei E3372. I bought it with a hi-link firmware, but flashed it into a stick mode (I need some local devices to be accessed from outside).
Initially it worked fine, I was able to pull “Info” from the modem, change and save its settings, etc. Now, for an unknown reason - I can’t do that. When changed a SIM card, I needed to set a new PIN, but I only saw an error message:
Couldn’t change Interface - no such info channel! (8)
Also, I’m unable to get device “Info”: Couldn’t start - Unable to acquire port! (6)
It’s important to note, that the device is working, transmitting data, etc. (I’m using it to post this).
- EDIT: some further information:
[admin@MikroTik] > /interface ppp-client print
0 R name="ppp-usb-modem" max-mtu=1500 max-mru=1500 mrru=disabled port=usb1 data-channel=0 info-channel=1 apn="internet" pin="****" user="internet" password="internet" profile=default phone="" dial-command="ATDT" modem-init="" null-modem=no dial-on-demand=yes
add-default-route=yes default-route-distance=0 use-peer-dns=yes keepalive-timeout=30 allow=pap,chap,mschap1,mschap2
Unable to get info or disable:
[admin@MikroTik] > /interface ppp-client info 0
failure: Unable to acquire port!
[admin@MikroTik] > /interface ppp-client disable 0
failure: no such info channel!
… but it’s working somehow!
[admin@MikroTik] > /interface ppp-client monitor 0
status: connected
uptime: 4m37s
encoding:
mtu: 1500
mru: 1500
local-address: 10.153.146.97
remote-address: 0.0.0.0
Of course I’ve tried to reset the router, but it didn’t help.
Then I’ve disconnected USB device and I was able to change setting, so I set new a PIN, attached the modem with a new SIM card, and it’s fully functional again.
[admin@MikroTik] /interface ppp-client> info 0
modem-status: ready
pin-status: no password required
functionality: full
manufacturer: huawei
model: E3372
revision: 21.180.01.00.00
access-technology: Evolved 3G (LTE)
signal-strengh: -63 dBm
Don’t know what to think about it… What happened?
Any advice?
Thanks!
