Cannot change hotmail Pasword behind mikrotik
Cannot change hotmail Pasword behind mikrotik, can any one help , i m using hotspot and mangle options too.
Need more detail. Chances are if you are behind a DSL router that you need to add a mangle to change the MSS value - this has been fairly well documented elsewhere.
thanks for reply, Acctually , i m not using dsl, its an international TWA banwidth for internet with a fiber optic link directely connected to my mikrotik Network Adapter, Even if i stop using mangle rules , it wont solve that problem, i think , it is some kind of double https page problem, i tried disabling all static firewall filters but nothing happen, may be its a hotspot problem.
one more thing,
i have two network running on two different location, with same mikrotik settings and i dont have any problem on the other mikrotik system ,
can u tell me if it is some kind of hardware compatability problem, with machine or network adapter may be.
waiting
Try to decrease the MSS
regards
faton
same problem after decreasing mss to 1460 and 1420
is your upload traffic OK,
yes , upload traffic is ok, more then 200 user r connected to mikrotik without having any kind of problem except , this hotmail options page.
Normis , can u help please?
thanks.
still waiting for help
