Cannot change YAML for builtin/app-store
Hello - I'm new to containers + apps. I have a fresh, licensed instance of CHR version 7.24.1 running on Hyper-V on 64bit Intel.
I try to 'enable' an app (any app), and I get met with a red pop-up that says "cannot change yaml for built-in/app-store apps".
This is a clean CHR - no customizations aside from giving it an IP address on it's uplink interface + setting up a bridge-LAN with a subnet tied to a second ethernet port. I have made no attempts to modify/configure the APP (in this case I'm selecting librenms, however, I've tried other apps as well).
I've configured a disk...
SYSTEM -> DISKS: I've set up a ext4 partition for containers (mount point 'sata2')
APP->SETTINGS:
Disk: sata 2
LAN bridge: bridge-LAN
Assumed router IP: 10.0.20.1
Show in Webfig: CHECK
Would anyone here have any pointers or ideas on what I've done wrong? All apps show the same error. The router is basically a default install 'out of the box'.
:thinking:
