Good day!
I cannot configure remote VPN user connections to use the Web application in the office.
The router MikroTik RB951G- 2HnD firmware 6.45.7. (Old broke, had to buy new)
When remote users (Windows Client) connected (at a white address) to the router (192.168.0.100), the VPN server on which the application was accessed is configured.
In Filter and NAT pictures
Such a scheme worked perfectly for more than a year.
But after replacing the router with the new firmware, it will not connect remotely to the VPN server.
I haven 't found a solution yet. What am I doing wrong? Practically set up one in one.
Ну что же меня выдает? Может лампас на штанах? А может фуражка?
Ответ: никто другой не понимает, что такое “серые” и “белые” адреса ![]()
Please don’t post screenshots; instead, follow the guide in my automatic signature just below to post your complete configuration in text form.
Before doing that, my fast bet is that you don’t have any port value set for the PPTP firewall helper, so ip firewall service-port set pptp ports=1701 might resolve your issue.
PPTP port is not 1701 ![]()
Also NAT helpers are used in case the router is behind NAT, how do you know that in this case the router is behind NAT ?
Glad you’ve noticed my mistake, but you might as well have told the OP the correct value 1723 straight away.
But he uses the correct value!
