I have only two firewall rule.
chain=srcnat action=masquerade out-interface=ether1
chain=dstnat action=dst-nat to-addresses=192.168.1.1 to-ports=80 protocol=tcp in-interface=ether1 dst-port=80
My problem is, I have 2 connection on the ether2 interface, 192.168.1.1 (.1 is a win 2012 server), 192.168.1.10 (.10 is a management win 10 client).
When I connect to the server WAN IP from my home PC the website loading, everything right. But when I try to connect from 1.10 management windows 10 client I am getting:
This site can’t be reached
If your connecting via a wireless ap connection you may have default forward not ticked which blocks client to client connections to the ap. That would explain if that’s how it’s setup. Or if it’s not setup like that you need to do some tests like ping the server from the router to check if it can connect to the gateway. If not check the tests from the server itself too. Sounds like your computer works OK or you wouldn’t be able to get online.
