I have this unit in service for a year now, and have upgraded ROS several times in that period. This week I upgraded to the -rc3 successfully, but I had some problems with my configuration afterwards. I decided to downgrade to 6.40. After the attempted downgrade, I can no longer communicate with the router by NetInstall or by serial cable, and the router is in a reboot loop.
When using NetInstall the router simply does not get detected, this with the router connected via the boot port eth12. With serial cable/PuTTY there is no output at all in the console when the router attempts to boot.
I am quite certain it is not damaged hardware, since the router has worked perfectly since I bought it, but it seems I have botched the upgrade/downgrade quite spectacularly.
Is there any other advice I can get to help me out with this? I am at a disadvantage because I am in Thailand, and getting tech support here in a language I’m not comfortable with is extremely difficult.
Thanks for any advice.
