Cannot connect to GrooveA 52
Trying to configure for the first time. Plugged in Ethernet from laptop to POE. Patch cable from POE out to GrooveA. Power plugged into POE. type in 192.168.88.1, Error message says “Cannot reach this page”. open Winbox, click neighbors, nothings is there. Using Windows 10.
Help is appreciated in advance!
Thanks,
-Joey
Over the past year I’ve occasionally gotten batches of GrooveGA 52ac’s set as AP bridges. In this case they don’t give out IP’s and they don’t have a statice IP. If this is the case with your GrooveA 52 then downloading and using Winbox.exe from the Mikrotik Software page will allow you to connect to the Groove using the MAC address. When you run Winbox you will see that the Groove has an IP of 0.0.0.0
