Hello!
I just moved my devices from the ISP router to hAP ax2. I only did the “quick setup”, no other configuration (also because I wouldn’t know where to begin
I cannot access Plex or Jellyfin from other devices on LAN anymore, internet acces is fine. Apparently some packets are interpreted as invalid and dropped by firewall rule 10. Disabling this rule allows me to connect as expected.
Here are some logs of rule 10 :
And sniff tool for the same requests:
Any idea why these requests are broken or how to troubleshoot further?
Thanks!
PS: my config:
# 2024-10-17 03:20:39 by RouterOS 7.15.2
# software id = xxxxxxxx
# model = C52iG-5HaxD2HaxD
# serial number = xxxxxxxxxxx
add admin-mac=xxxxxxxxxx auto-mac=no comment=defconf name=bridge
/interface wifi
set [ find default-name=wifi1 ] channel.skip-dfs-channels=10min-cac \
configuration.country=Italy .mode=ap .ssid="computer mkt" disabled=no \
security.authentication-types=wpa2-psk,wpa3-psk .ft=yes .ft-over-ds=yes
set [ find default-name=wifi2 ] channel.skip-dfs-channels=10min-cac \
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp interface=bridge name=defconf
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
/ipv6 settings
set disable-ipv6=yes
/interface detect-internet
set detect-interface-list=all
add address=192.168.88.1/16 comment=defconf interface=bridge network=\
192.168.0.0
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
/ip dhcp-server lease
add address=192.168.88.11 client-id=1:xxxxxxxxxxxx mac-address=\
xxxxxxxxxxxxxxxxx server=defconf
add address=192.168.0.0/16 comment=defconf dns-server=192.168.88.1 gateway=\
192.168.88.1 netmask=16
set allow-remote-requests=yes servers=9.9.9.9,149.112.112.112 use-doh-server=\
https://dns.quad9.net/dns-query verify-doh-cert=yes
/ip dns static
add address=192.168.88.11 name=computer
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
add interface=ether1 type=external
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
dst-port=33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=Europe/Rome
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
