Cannot connect to other LAN via VPN
Can someone please help?
The setup is as follows:
We use PPTP VPN on internal IP range 172.16.16.0/24. My house IP range is 192.168.10.0/24. The HQ is on 192.41.100.0/24 and the other on 192.168.6.0/24. I setup NAT and routing on both ends, but cannot connect to PC’s and printers on the 192.168.6.0/24 range, i.e. 192.168.6.101 and 192.168.6.20 from my laptop on 192.168.10.13. I can connect to the HQ equipment on 192.41.100.0/24
i.e. the connection is as follows: My Laptop (192.168.10.100) → VPN (172.16.16.103) → Internet → HQ via VPN (172.16.16.1)
Remote branch is as follows: Printer (192.168.6.20) → VPN (172.16.16.106) → Internet - HQ via VPN
Running a traceroute to the networks from my laptop:
C:\Users\Rudi>tracert 192.41.100.250
Tracing route to 192-41-100-250.c7dc.com [192.41.100.250]
over a maximum of 30 hops:
  1     1 ms     1 ms     1 ms  192.168.10.1
  2    36 ms    30 ms    47 ms  172.16.16.1
  3    31 ms    30 ms    44 ms  192-41-100-250.c7dc.com [192.41.100.250]
  C:\Users\Rudi>tracert 192.168.6.20
Tracing route to 192.168.6.20 over a maximum of 30 hops
  2    31 ms    31 ms    28 ms  172.16.16.1
  3     *        *        *     Request timed out.
  4     *        *        *     Request timed out.
  5     *        *        *     Request timed out.
  6     *        *        *     Request timed out.
  7     *        *        *     Request timed out.
  8     *        *        *     Request timed out.
  9     *        *        *     Request timed out.
 10     *        *        *     Request timed out.
 11     *        *        *     Request timed out.
 12     *        *        *     Request timed out.
 13     *        *        *     Request timed out.
 14     *        *        *     Request timed out.
 15     *        *        *     Request timed out.
 16     *        *        *     Request timed out.
 17     *        *        *     Request timed out.
 18     *        *        *     Request timed out.
 19     *        *        *     Request timed out.
 20     *        *        *     Request timed out.
 21     *        *        *     Request timed out.
 22     *        *        *     Request timed out.
 23     *        *        *     Request timed out.
 24     *        *        *     Request timed out.
 25     *        *        *     Request timed out.
 26     *        *        *     Request timed out.
 27     *        *        *     Request timed out.
 28     *        *        *     Request timed out.
 29     *        *        *     Request timed out.
 30     *        *        *     Request timed out.
Trace complete.
Please see attached the network diagram.
traffic towards 192.168.6.20 should be routed to 172.16.16.106, not 172.16.16.1
change your static routing at home router
You will need the following routes at:
HQ:
192.168.6.0/24 via PPTP-1 (To Remote)
192.168.10.0/24 Via PPTP-2 (To Home)
Home:
192.168.1.0/24 via PPTP-1 (To HQ)
192.168.6.0/24 via PPTP-1 (To Remote via HQ)
Remote:
192.168.10.0/24 via PPTP-1 (To Home via HQ)
That doesn’t make sense. 172.16.16.106 sits on the other network and cannot be reached from 1921.168.10.1 directly. Even adding it as a route shows it as unreachable
I have these routes already, thought the IP’s are slightly different from yours. Look at the attached image to see.
So I have:
HQ:
[admin@MikroTik] > /ip route print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
 0 A S  0.0.0.0/0                          x.x.x.x           1
 1 X S  0.0.0.0/0                          y.y.y.y            2
 2 X S  0.0.0.0/0                          afrihost                  3
25 ADC  172.16.2.0/24      172.16.2.1      ether1-Fiber              0
26 X S  172.16.16.0/24                     172.16.16.1               1
27 ADC  172.16.16.44/32    172.16.16.1     <pptp-RudiA>              0
28 ADC  172.16.16.101/32   172.16.16.1     <pptp-CTVPN>              0
29 ADC  172.16.16.102/32   172.16.16.1     <pptp-DBNVPN-1>           0
30 ADC  172.16.16.106/32   172.16.16.1     <pptp-VERVPN>             0
31 ADC  192.41.100.0/24    192.41.100.1    ether4                    0
32 A S  ;;; DBN VPN
        192.168.1.0/24                     172.16.16.102             1
33 A S  ;;; Cape Town Network via Bitco Fiber
        192.168.4.0/24                     <pptp-CTVPN>              1
34   S  ;;; Cape Town Network via LTE
        192.168.4.0/24                     172.16.16.101             2
Home:
192.41.100.0/24 via PPTP-1 (To HQ)
[admin@MT] > /ip route print
 0 A S  0.0.0.0/0                          192.168.18.1              1
 1 ADC  172.16.16.1/32     172.16.16.44    HST                       0
 2 A S  192.41.100.0/24                    HST                       1
 3 A S  192.168.1.0/24                     HST                       1
 4 A S  192.168.6.0/24                     HST                       1
5 ADC  192.168.10.0/24    192.168.10.1    bridge                    0
6 ADC  192.168.18.0/24    192.168.18.2    ether1                    0
HST is the VPN connection name.
Remote:
[admin@Vereeniging] > /ip route print
 1 ADC  154.127.113.72/29  x.x.x.y  ether1-Fiber              0
 2 ADC  172.16.16.1/32     172.16.16.106   JHB-VPN                   0
 3 A S  192.41.100.0/24                    JHB-VPN                   1
 4 ADC  192.168.6.0/24     192.168.6.1     bridge                    0
 5 A S  192.168.10.0/24                    JHB-VPN                   1
The IP subnets I got from the description in your original post
The home and remote sides looks ok.
There are 2 different route prints for HQ, not sure why. Also, if I follow the route numbers, there seems to be routes missing as it jumps from number 3 to a big number, I assume the reason is there are some dynamics c routes not shown in print of routes.
I also do not see where you are routing to either .192.168.10x or .6.x in the print for HQ?
The 3 main subnets are:
home: 192.168.10.0/24
HQ: 192.41.100.0/24
Remote Office: 192.168.6.0/24
I took out some sensitive routes, but that has nothing todo with the routes I cannot get to work right now.
Hmm, it seems it got cut off when I copied from Winbox. Here it is:
38 A S  ;;; Vereeniging VPN
        192.168.6.0/24                     <pptp-VERVPN>             1
39   S  192.168.8.0/24                     10.1.1.1                  1
40 A S  192.168.10.0/24                    <pptp-RudiA>              1
41  DC  192.168.20.0/24    192.168.20.1    ether10-VOIP            255
What does firewall filter rules look like, anything that will block comms between these subnets?
Just reread your OP, you mention you have enabled NAT, is this NATing through the vpn? If so, that might be your problem, remove this and use routing only
