Hi! I have MikroTik hap ax3 and i cannot connect to the router. Once I bought it I’ve connected via WiFi and probably changed default DHCP settings (I don’t really remember for sure) for something like 192.168.78.0/24. Once I checked that my Internet is connected and working fine - I’ve turned router off for about a week.
After that I plugged in the power cable and now WiFi doesn’t start and if I try to connect via ethernet cable - I get “unknown network”.
Ethernet in my laptop is set to aquire address automatically and my IP in this case is something like 100.65.9.44 with a mask 255.255.240.0.
If I set it manually to 192.168.78.10 with a 255.255.255.0 mask and host 192.168.78.1 - i cannot connect too.
I’ve tried to reset my router to factory defaults by pressing reset, plugging in the power and waiting till green LED starts flashing and then letting go the button - but it didn’t help.
Is there a way to recover my router?
