I have situation that is odd, to me.
I am running some compute services on two machines on the LAN. 4 instances of the compute service run on each of the two machines. They use ports 3000-3003
The services appear to run correctly as I can telnet to them from the host machine (itself), but I am unable to telnet to a service running on a different machine. They also cannot be discovered on the network when I use the management software to connect to the compute services. Host machines are not blocking ports.
In other words I have this:
Compute machine 1: 192.168.88.xx: 3000-3003
Compute machine 2: 192.168.88.xy: 3000-3003
Management node: 192.168.88.xz
I can telnet to a service from machine 1 to machine 1, but I cannot telnet from machine 1 to machine 2 (and vice versa) and management node does not find any services on the LAN.
How do I enable LAN connectivity on the ports 3000-3003? Also I may need to run more services and more compute machines so a permanent solution that does not require messing with the firewall every time the compute topology changes would be preferable. I only need them to be accessible inside the same LAN.
Thank you,
V.
