Cannot connect to switchOS ip CRS317-1G-16S+RM
I wanted to boot to switchOS from routerOS but as soon as I set to boot to switchOS I cannot connect to the default ip, neighborview shows an ip of 0.0.0.0 which is invalid. Is there a way to completely reset the switch os firmware?
I tried to do the reset switch button but it only resets back to factory for routeros not switchos
Connect to device via console, you can reset and upgrade device through there.
Thanks for the Input, that solved it for me :smiley:
