Cannot connect to the internet with PPOE with vlan
I am trying to connect my mikrotik router to the internet with a fibre modem.
Following the instructions, I created a VLAN 40 on eth1 and attached the PPOE client with the provided username and password.
I am pretty sure that I am connected because I can see an IP in the PPOE interface and using the ping tool in winbox i can ping 8.8.8.8. But I am not able to connect to the internet on any of my computers.
I did a config reset to clear all settings just in case I had something that was blocking it but I still can’t connect.
Here’s the config:
# jan/02/1970 01:35:41 by RouterOS 6.49.6
# software id = KDZ0-FPEH
# model = RB750Gr3
# serial number = D5030FF9A03F
add admin-mac=DC:2C:6E:B6:37:5E auto-mac=no comment=defconf name=bridge
/interface vlan
add interface=ether1 mtu=1492 name=EboxVlan vlan-id=40
/interface pppoe-client
add add-default-route=yes disabled=no interface=EboxVlan max-mtu=1492 name=\
    EboxPPOE user=eee@ee.ee.net
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
    192.168.88.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1 use-peer-dns=no
    192.168.88.1
set allow-remote-requests=yes
/ip dns static
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
/system logging
add topics=dhcp
add topics=dhcp
/tool mac-server
/tool mac-server mac-winbox
Any help with getting this working is appreciated.
/interface vlan
That is wrong. mtu should not be set to 1492 there. Remove that.
The new WAN interface needs adding to the WAN interface list, otherwise there will be no internet access from the LAN:
add interface=EboxPPOE list=WAN
you can also remove ether1 from the list, and disable or remove the DHCP client.
With the above advice, you should be good to go!! All points covered.
The one that stood out for me was this needs to be disabled or removed (and the wan interface list)
/ip dhcp-client
