Cannot connect to wifi on hAP ac3 + cAP with CAPSMAN and wifi-qcom-ac, with wireless it works
Hi all,
I have recently install package wifi-qcom-ac into hAP ac3 with 7.18.2 . This serves as CAPSMAN. I installed the same package wifi-qcom-ac to cAP ac with 7.18.2. When I’m connecting to cAP ac it works perfectly and the performance is better than before with wireless package. But the wifi connection to hAP ac3 does not work even I have enough signal strength.
So I installed package wireless on hAP ac3 back again and the wifi connection works well.
Here are the config files of the hAP ac3 with wifi-qcom-ac:
# 2025-03-26 19:43:27 by RouterOS 7.18.2
# software id = XXXX-XXXX
# model = RBD53iG-5HacD2HnD
# serial number = XXXXXXXXXXXX
/interface bridge add admin-mac=XXXXXXXXXX auto-mac=no comment=defconf name=bridge port-cost-mode=short
/interface list add comment=defconf name=WAN
/interface list add comment=defconf name=LAN
/interface lte apn set [ find default=yes ] use-network-apn=no
/interface wifi datapath add bridge=bridge comment=defconf disabled=no name=capdp
/interface wifi security add authentication-types=wpa2-psk,wpa3-psk disabled=no name=security1_AC
/interface wifi configuration add country=Czech disabled=no name=cfg_AC security=security1_AC ssid=XX
/ip pool add name=dhcp ranges=10.1.10.2-10.1.10.254
/ip dhcp-server add address-pool=dhcp interface=bridge lease-time=1h10m name=defconf
/routing bgp template set default disabled=no output.network=bgp-networks
/routing ospf instance add disabled=no name=default-v2
/routing ospf area add disabled=yes instance=default-v2 name=backbone-v2
/ip smb set enabled=no
/interface bridge port add bridge=bridge comment=defconf ingress-filtering=no interface=ether2 internal-path-cost=10 path-cost=10
/interface bridge port add bridge=bridge comment=defconf ingress-filtering=no interface=ether3 internal-path-cost=10 path-cost=10
/interface bridge port add bridge=bridge comment=defconf ingress-filtering=no interface=ether4 internal-path-cost=10 path-cost=10
/interface bridge port add bridge=bridge comment=defconf ingress-filtering=no interface=ether5 internal-path-cost=10 path-cost=10
/interface bridge port add bridge=bridge comment=defconf ingress-filtering=no interface=*1 internal-path-cost=10 path-cost=10
/interface bridge port add bridge=bridge comment=defconf ingress-filtering=no interface=*2 internal-path-cost=10 path-cost=10
/ip neighbor discovery-settings set discover-interface-list=LAN
/ipv6 settings set max-neighbor-entries=8192
/interface detect-internet set detect-interface-list=all
/interface list member add comment=defconf interface=bridge list=LAN
/interface list member add comment=defconf interface=ether1 list=WAN
/interface wifi capsman set enabled=yes package-path="" require-peer-certificate=no upgrade-policy=suggest-same-version
/interface wifi provisioning add action=create-dynamic-enabled disabled=no master-configuration=cfg_AC name-format="CAP - %I, %r"
/ip address add address=10.1.10.1/24 comment=defconf interface=ether2 network=10.1.10.0
/ip address add address=XXX.XXX.XXX.XXX/16 interface=ether1 network=XXX.XXX.XXX.XXX
/ip dhcp-client add comment=defconf disabled=yes interface=ether1
/ip dhcp-server network add address=10.1.10.0/24 comment=defconf gateway=10.1.10.1 netmask=24
/ip dns set allow-remote-requests=yes servers=XXX.XXX.XXX.XXX,XXX.XXX.XXX.XXX
/ip dns static add address=10.1.10.1 comment=defconf name=router.lan type=A
/ip firewall filter add action=jump chain=forward comment="jump to kid-control rules" jump-target=kid-control
/ip firewall filter add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
/ip firewall filter add action=drop chain=input comment="defconf: drop invalid" connection-state=invalid
/ip firewall filter add action=accept chain=input comment="defconf: accept ICMP" protocol=icmp
/ip firewall filter add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
/ip firewall filter add action=drop chain=input comment="defconf: drop all not coming from LAN" in-interface-list=!LAN
/ip firewall filter add action=accept chain=forward comment="defconf: accept in ipsec policy" ipsec-policy=in,ipsec
/ip firewall filter add action=accept chain=forward comment="defconf: accept out ipsec policy" ipsec-policy=out,ipsec
/ip firewall filter add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
/ip firewall filter add action=accept chain=forward comment="defconf: accept established,related, untracked" connection-state=established,related,untracked
/ip firewall filter add action=drop chain=forward comment="defconf: drop invalid" connection-state=invalid
/ip firewall filter add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ip firewall nat add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=out,none out-interface-list=WAN
/ip ipsec profile set [ find default=yes ] dpd-interval=2m dpd-maximum-failures=5
/ip route add disabled=no dst-address=0.0.0.0/0 gateway=XXX.XXX.XXX.XXX
/ip service set telnet port=2300
/ip service set ssh port=2200
/ip ssh set strong-crypto=yes
/routing bfd configuration add disabled=no
/system clock set time-zone-name=Europe/Prague
/system identity set name="Pod schody"
/system logging add topics=wireless,debug
/system logging add topics=caps
/system note set show-at-login=no
/tool mac-server set allowed-interface-list=LAN
/tool mac-server mac-winbox set allowed-interface-list=LAN
Here is the config files of the hAP ac3 with wireless:
# 2025-03-26 19:10:48 by RouterOS 7.18.2
/caps-man channel add band=2ghz-g/n control-channel-width=20mhz extension-channel=Ce name=channel_2
/caps-man channel add band=5ghz-n/ac control-channel-width=20mhz extension-channel=Ceee name=channel_5
/interface wireless
# managed by CAPsMAN
# channel: 2452/20-Ce/gn(17dBm), SSID: XX, CAPsMAN forwarding
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX country="czech republic" distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=XX wireless-protocol=802.11
/interface wireless
# channel: 5180/20-Ceee/ac/P(17dBm), SSID: XX, CAPsMAN forwarding
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX country="czech republic" distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=XX wireless-protocol=802.11
/caps-man datapath add bridge=bridge client-to-client-forwarding=yes name=datapath1
/caps-man security add authentication-types=wpa2-psk encryption=aes-ccm name=security1
/caps-man configuration add channel=channel_2 country="czech republic" datapath=datapath1 distance=indoors installation=indoor mode=ap name=cfg_2 security=security1 ssid=XX
/caps-man configuration add channel=channel_5 country="czech republic" datapath=datapath1 installation=indoor mode=ap name=cfg_5 security=security1 ssid=XX
/caps-man configuration add country="czech republic" datapath=datapath1 installation=indoor mode=ap name=cfg1 security=security1 ssid=XX
/interface wireless security-profiles set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik
/caps-man manager set enabled=yes upgrade-policy=suggest-same-version
/caps-man provisioning add action=create-dynamic-enabled hw-supported-modes=gn master-configuration=cfg_2 name-format=prefix-identity name-prefix=2GHz-
/caps-man provisioning add action=create-dynamic-enabled hw-supported-modes=ac,an master-configuration=cfg_5 name-format=prefix-identity name-prefix=5GHz-
/caps-man provisioning add action=create-dynamic-enabled disabled=yes master-configuration=cfg1 name-format=prefix-identity
/interface bridge port add bridge=bridge comment=defconf ingress-filtering=no interface=wlan1 internal-path-cost=10 path-cost=10
/interface bridge port add bridge=bridge comment=defconf ingress-filtering=no interface=wlan2 internal-path-cost=10 path-cost=10
/interface wireless cap
set caps-man-addresses=127.0.0.1 enabled=yes interfaces=wlan1,wlan2
Here is the config files of the cAP ac with wifi-qcom-ac:
# 2025-03-26 19:33:35 by RouterOS 7.18.2
# model = RBcAPGi-5acD2nD
/interface bridge add admin-mac=XXXXXXXXXX auto-mac=no comment=defconf name=bridgeLocal
/interface wifi datapath add bridge=bridgeLocal comment=defconf disabled=no name=capdp
/interface wifi
# managed by CAPsMAN XXXXXXXXXX%bridgeLocal, traffic processing on CAP
# mode: AP, SSID: VS, channel: 2412/n/Ce
set [ find default-name=wifi1 ] configuration.manager=capsman datapath=capdp disabled=no
/interface wifi
# mode: AP, SSID: VS, channel: 5500/ac/Ceee/D
set [ find default-name=wifi2 ] configuration.manager=capsman datapath=capdp disabled=no
/interface bridge port add bridge=bridgeLocal comment=defconf interface=ether1
/interface bridge port add bridge=bridgeLocal comment=defconf interface=ether2
/interface wifi cap set discovery-interfaces=bridgeLocal enabled=yes
/ip dhcp-client add comment=defconf interface=bridgeLocal
/system identity set name="Technicka mistnost 1. patro"
/tool graphing interface add
/tool graphing queue add
/tool graphing resource add
When the hAP ac3 has wifi-qcom-ac loaded I see in the log following infos:
XX:XX:XX:XX:XX:XX@CAP - ac, xxxxxxxxxxx disconnected, connection lost, signal strength-70
XX:XX:XX:XX:XX:XX@CAP - ac, xxxxxxxxxxx disassociated, connection lost, signal strength-70
XX:XX:XX:XX:XX:XX@CAP - ac, xxxxxxxxxxx connected, signal strength-45
XX:XX:XX:XX:XX:XX@CAP - ac, xxxxxxxxxxx associated, signal strength -45
XX:XX:XX:XX:XX:XX@CAP - ac, xxxxxxxxxxx disconnected, connection lost, signal strength-50
XX:XX:XX:XX:XX:XX@CAP - ac, xxxxxxxxxxx disassociated, connection lost, signal strength-50
XX:XX:XX:XX:XX:XX@CAP - ac, xxxxxxxxxxx associated, signal strength-47
XX:XX:XX:XX:XX:XX@CAP - ac, xxxxxxxxxxx connected, signal strength -47
Do you have any idea why the wifi connection is not working?
This is a problem:
Probably the two wifi interfaces, as soon as you see an asterisk you know there probably is a problem.
You would have to add wifi1 and wifi2 to the bridge and either provision manually or set configuration cfg_AC to both wifi interfaces. More info on provisioning can be found here:
https://help.mikrotik.com/docs/spaces/ROS/pages/224559120/WiFi#WiFi-RadioProvisioning
Have fun using wifi-qcom-ac, it is indeed much better!
Thanks erlinden for your advice.
I tried it to solve it. I removed the wifi configuration, then corrected the interface names are correctly wifi1 and wifi2. Then I activated the wifi configuration again and the strange interface names with asterisk are back.
After removing the wifi configuration the ports looks like:
add bridge=bridge comment=defconf ingress-filtering=no interface=wifi1     internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=wifi2
Then I again activate the wifi configuration by:
add country=Czech disabled=yes name=cfg_AC security=security1_AC ssid=XX
And the strange names are back, this time with letters:
add bridge=bridge comment=defconf ingress-filtering=no interface=*E     internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=*F     internal-path-cost=10 path-cost=10
Any other idea?
Did you hit the provision button? I assume that the wifi interfaces are added to the bridge dynamically (as well for the CAP).
Does this problem also occur when you leave names untouched?
Have you checked the log?
Actually I need to touch the names. Whenever I switch off the WIFI configuration, their names are returned back to wifi1 and wifi2. Once I switch the wifi configuration they get these strange names..
I did press the provision button without any effect.
I did not yet check the log. Which information topic shall I look for? Shall I add any topics like:
/system logging
add topics=caps
Use create-static instead of create-dynamic. Dynamic interface are recreated with new id on each change.
Indeed, debug logging can add something.
Please do these steps as test (make sure everything from wifi is removed befor hand):
# reset both wifi interfaces:
/interface/wifi reset wifi1
/interface/wifi reset wifi2
# verufy they are part of the bridge (or add them):
/interface bridge port add bridge=bridge comment=defconf ingress-filtering=no interface=wifi1
/interface bridge port add bridge=bridge comment=defconf ingress-filtering=no interface=wifi2
# start wifi configuration:
/interface/wifi/ set [find name=wifi1] configuration=cfg_AC
/interface/wifi/ set [find name=wifi2] configuration=cfg_AC
Do you local wifi interfaces work?
Now you can set the cAP ac to CAPS Mode and add the provision rule on the CAPsMAN:
Hope this helps.
Thanks erlinden. It works now!
The issue likely was that I did provisioning of wifi1 and wifi2 in Wifi-Radios section. With that I supposed that also the local wifi is managed by CAPSMAN.
The config looks as follows now:
add disabled=no name=cfg_AC security=security1_AC ssid=XX
/interface wifi
set [ find default-name=wifi1 ] configuration=cfg_AC configuration.mode=ap \
    disabled=no
set [ find default-name=wifi2 ] configuration=cfg_AC configuration.mode=ap \
    disabled=no
add bridge=bridge comment=defconf ingress-filtering=no interface=ether2 \
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3 \
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4 \
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5 \
set enabled=yes package-path="" require-peer-certificate=no upgrade-policy=\
add action=create-dynamic-enabled disabled=no master-configuration=cfg_AC \
One follow-up question. Now the local wifi1/2 ar configured with the same cfg_AC as CAPSMAN uses for the CAP. So SSID is the same. But will the roaming work well if local wifi1/2 are not included in CAPSMAN?
Yes!
