Cannot connect two hAp ac light routerboards via POE
I currently have 2 hAp ac lite routers (952Ui-5ac2nD) that I am trying to connect via POE.
The main router seems to power on the secondary one without any issue, but it does not seem as though there is any TCP connection between the two. When I connect the network cable to either of the routers then winbox can detect only the one that I am currently connected to.
I know that the cables are working as it’s a new installation, and I tested using a cable tester. But when I run the cable test in terminal, it just gives these results:
interface ethernet cable-test ether1
       status: no-link
  cable-pairs: shorted:24,normal:?,open:19,open:16
-- [Q quit|D dump|C-z pause]
Could this mean that there is some issues with the physical port? And if so, how do I diagnose it?
