I have an RB532 2.9.38 with a cm9 radio and a few IBM notebooks with an Intel 3945 A/B/G Wireless card that cannot even see the access points.
I tried adjusting the propority extensions to no avail.
Is there any known Incompatibilitys?
Thank you
Make sure that the notebooks are using the latest intel wireless card drivers.
We use HP Notebooks with the same card/chipset. Windows XP prof. works without problems at 2.4GHz and 5GHz.
it sounds like this is a centrino chipset? you need post 2.9.25 proprietary-extensions
thats true. it was introduced due to that problem, that new macbooks and other alike (chipsetwise) had problems. to get rit you have to set
code will set this enabled on all wireless interfaces in router so be careful, f needed replace [find] part
/interface wireless set [find] proprietary-extensions=post-2.9.25
