When I activate VLAN filter I loose access to my Mikrotik device (I’ts an HAP ac2 btw). I had to reset it and backup. DHCP also doesn’t work and I just noticed, I’m lost and this is giving me headache.
To configure without headache do the following. (temporary)
Take ether5 off the bridge ( so not identifed on /interface bridge ports or /interface bridge vlans )
Give ether5 its own IP address like 192.168.55.1/24
Change IPV4 settings on desktop or laptop and give it an Ip address of 192.168.55.5 for example.
You can now config the router safe from any bridge vlan changes by plugging into ether5
Ether5 is where I recieve Internet, I tried to disconnect it from the bridge and had to reset again. You mean as a port of the bridge or as a subinterface? Becouse as a subinterface doesn’t let me do it and as a port just told you what happened before.
Sorry didnt realize ether5 was internet, let me rephrase… Take any one ethernet port ( not WAN ) that you can temporarily modify ( ether1,2,3,4 ??? ) off the bridge.
So why was ether5 on your bridge ports then if it was the WAN ???
But the other ports are not connected phisically to the network, does that matter? Anyways I’m gonna try. I guess the “Internet port” should be ether1 but in my company they have connected it to ether5 and in defconf, this ether5 comes connected to bridgelocal and if you disconnect it you loose access to the device and have to reset it.
There are control freaks here who think you should have to go into the router/switch configuration to explicitly enable the port when plugging a new device in. Me, I just bridge all the LAN-side ports and be done with it. Decide which kind of network admin you are, and do it that way.
The real point here is that for normal use, you should never bridge the WAN port to the LAN. That bypasses the firewall and NAT layers!
The only exception I can think of is that you’re running an old-school direct-Internet-access service straight out of the late 1980s, as when you’re distributing a public AS block in an ISP, or you’re doing IPv6-only, or similar.
That’s perfectly fine. I do the same thing on my hAP ax³ here because of the MT engineers’ questionable design decision to make ether1 the device’s sole PoE port. My cable modem neither provides nor consumes PoE, and so with this righteous justification, I moved the WAN port to the other end of the device.
I don’t use PoE on that device today, but I now have that option without reconfiguring my Internet gateway first.
RouterOS is uncommonly flexible. Your job as admin is to tell it what you want it to do, not the other way around.
Then changing ether1 to be the Internet port should be all? That makes sense becouse in that way I could activate the vlan filtering in the bridge and make VLANs to create the network 99 (guests network). Thank you I’ll try. Please if I’m wrong or it is something missing I would be grateful if you communicate to me. Thank you tangent for the explanation.
I just tried and cant make connection with no other port that is out of the local bridge, don’t know why. I’m gonna try to make the WLANs run in other bridge appart from the local one. Should I connect ether1 to the local bridge and connect to the bridge through it or I just keep connecting to the bridge with ether5?
I rode this post http://forum.mikrotik.com/t/can-someone-tell-me-how-to-make-a-capsman-guest-network-with-new-drivers-ax-and-ac-devices/171363/1 that says that if you create a VLAN on the ether port that is connected your mikrotik device and you attach it as a port in guests bridge should work, but doesn’t for me. Is that well configured or not? And another point is that my DHCP doesn’t work properly, it is not assigning the IPs well and devices don’t appear in leases. When I connect to my guests Wi-Fi gives me IPs from the local bridge and not even in the range of local Wi-Fi DHCP. I need help.
