I have run several wireguard and today I wanted to create a new connection, so I created the wireguard interface as usual but found the interface is not up. I tried disable it and then enable it but no luck. It is CCR2116 running v7.15.2
What caused this issue ? Any one ever had same problem before ?
[brg3466@CCR2116] > /interface/wireguard/add name=WG71 listen-port=55571
[brg3466@CCR2116] > /interface/wireguard/print
Flags: X - disabled; R - running
5 R ;;; to_1502
name="WG21" mtu=1420 listen-port=55521 private-key="xxx" public-key="yyy"
6 name="WG71" mtu=1420 listen-port=55571 private-key="xxx" public-key="yyy"
