I bought a Mikrotik hex because the netgear wifi6e device I have doesn’t support VLAN tagging on the WAN interface, as required by CenturyLink. However, I’m unable to get a DHCP address with the hex device. According to CenturyLink, the router just need to be configured with VLAN id 201 and is IPoE, not PPPoE. So, with an up to date version of RouterOS, I’ve created a VLAN interface, assigned it to ethernet1 (which is the one connected to the fiber device in my house), and set the DHCP client to use the VLAN. However, it’s not receiving an IP address. Any ideas on what could be wrong here? Here is the config export:
# 2023-11-05 14:57:55 by RouterOS 7.11.2
# software id = GENI-YT7H
# model = RB750Gr3
# serial number = 12345
add admin-mac=18:FD:74:FC:D4:8E auto-mac=no comment=defconf name=bridge
/interface vlan
add interface=ether1 name=QuantumFiber vlan-id=201
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
/ip hotspot profile
add address-pool=default-dhcp interface=bridge lease-time=10m name=defconf
/port
set 0 name=serial0
add bridge=bridge comment=defconf ingress-filtering=no interface=ether2
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5
/ipv6 settings
/interface ovpn-server server
set auth=sha1,md5
192.168.88.0
/ip dhcp-client
add comment=defconf interface=QuantumFiber
set allow-remote-requests=yes
/ip dns static
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/routing bfd configuration
add disabled=no interfaces=all min-rx=200ms min-tx=200ms multiplier=5
/system clock
set time-zone-name=America/Los_Angeles
/system identity
set name=nwrye
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
I’m doing all the configs through the web UI, not the terminal.
