Cannot Downgrade RouterOS 3.25 by any way.
Hello
I have Bought a RouterBoard 450G with RouterOs level4 version 3.11 .
I configured Hotspot+Usermanager on it and and everything seemed Ok.
i saw that mikrotik RouterOs 3.25 (Stable Version) was released and i decided to upgrade the routerOs to version 3.25.
unfortunately there are 2 big problems in version 3.25:
1- as u configure Usermanager in version 3.25 the CPU Usage goes up from 50% to above 90% and the hotspot gets DOWN within less than 5 hours and even the hotspot login page will not be available on hotspot users.
1- because of that problem i want to change back to the previous version of mikrotik but unfortunately i cant do this by any way .
as u click on Downgrade button and the routeros restarts , i see that no change was made on routeros and the version 3.25 is still on routerboard.
I really dont know what to do .
Any suggestion is appreciated.
I know what to do - /log print
Have you copied a valid ROS file into the files directory before you downgrade?
BTW There is no RouterBoard 455. Are you sure it is not an RB450?
Tom
ofcourse yes.
I have downloaded the complete package directly from mikrotik.com
so what is in /log print ? it’s the most informative thing
Jan/01/1970 00:00:15 system,error can not install dude-3.13: system-3.13 is not installed, but is required
Jan/01/1970 00:00:15 system,error can not install mpls-3.13: system-3.13 is not installed, but is required
Jan/01/1970 00:00:15 system,error can not install advanced-tools-3.13: system-3.13 is not installed, but is required
Jan/01/1970 00:00:15 system,error can not install calea-3.13: system-3.13 is not installed, but is required
Jan/01/1970 00:00:15 system,error can not install dhcp-3.13: system-3.13 is not installed, but is required
Jan/01/1970 00:00:15 system,error can not install gps-3.13: system-3.13 is not installed, but is required
Jan/01/1970 00:00:15 system,error can not install hotspot-3.13: system-3.13 is not installed, but is required
Jan/01/1970 00:00:15 system,error can not install ipv6-3.13: system-3.13 is not installed, but is required
Jan/01/1970 00:00:15 system,error can not install multicast-3.13: system-3.13 is not installed, but is required
Jan/01/1970 00:00:15 system,error can not install ntp-3.13: system-3.13 is not installed, but is required
Jan/01/1970 00:00:15 system,error can not install ppp-3.13: system-3.13 is not installed, but is required
Jan/01/1970 00:00:15 system,error can not install routerboard-3.13: system-3.13 is not installed, but is required
Jan/01/1970 00:00:15 system,error can not install routing-3.13: system-3.13 is not installed, but is required
Jan/01/1970 00:00:15 system,error can not install security-3.13: system-3.13 is not installed, but is required
Jan/01/1970 00:00:15 system,error can not install ups-3.13: system-3.13 is not installed, but is required
Jan/01/1970 00:00:15 system,error can not install user-manager-3.13: system-3.13 is not installed, but is required
Jan/01/1970 00:00:15 system,error can not install wireless-3.13: system-3.13 is not installed, but is required
Jan/01/1970 00:00:15 system,info router rebooted
well, it seems like you forgot to upload system-3.13.npk =)
i tried again but the downgrade wont works in practice.
Rebooting…
Stopping services…
enabled ipv6-3.25
verified wireless-3.11-mipsbe.npk
verified user-manager-3.11-mipsbe.npk
verified ups-3.11-mipsbe.npk
verified system-3.11-mipsbe.npk
verified security-3.11-mipsbe.npk
verified routing-test-3.11-mipsbe.npk
verified routing-3.11-mipsbe.npk
verified routerboard-3.11-mipsbe.npk
verified ppp-3.11-mipsbe.npk
verified ntp-3.11-mipsbe.npk
verified multicast-3.11-mipsbe.npk
verified mpls-test-3.11-mipsbe.npk
verified mpls-3.11-mipsbe.npk
verified ipv6-3.11-mipsbe.npk
verified hotspot-3.11-mipsbe.npk
verified gps-3.11-mipsbe.npk
verified dude-3.11-mipsbe.npk
verified dhcp-3.11-mipsbe.npk
verified calea-3.11-mipsbe.npk
verified advanced-tools-3.11-mipsbe.npk
WARNING: omitting package system-3.11: it does not support current file system
ERROR: can not install advanced-tools-3.11: system-3.11 is not installed, but id
ERROR: can not install calea-3.11: system-3.11 is not installed, but is required
ERROR: can not install dhcp-3.11: system-3.11 is not installed, but is required
ERROR: can not install dude-3.11: system-3.11 is not installed, but is required
ERROR: can not install gps-3.11: system-3.11 is not installed, but is required
ERROR: can not install hotspot-3.11: system-3.11 is not installed, but is requid
ERROR: can not install ipv6-3.11: system-3.11 is not installed, but is required
ERROR: can not install multicast-3.11: system-3.11 is not installed, but is reqd
ERROR: can not install ntp-3.11: system-3.11 is not installed, but is required
ERROR: can not install ppp-3.11: system-3.11 is not installed, but is required
ERROR: can not install routerboard-3.11: system-3.11 is not installed, but is rd
ERROR: can not install routing-test-3.11: system-3.11 is not installed, but is d
ERROR: can not install mpls-test-3.11: system-3.11 is not installed, but is reqd
ERROR: can not install mpls-3.11: system-3.11 is not installed, but is required
ERROR: can not install routing-3.11: system-3.11 is not installed, but is requid
ERROR: can not install security-3.11: system-3.11 is not installed, but is requd
ERROR: can not install ups-3.11: system-3.11 is not installed, but is required
ERROR: can not install user-manager-3.11: system-3.11 is not installed, but is d
ERROR: can not install wireless-3.11: system-3.11 is not installed, but is requd
Restarting system.
You will not be able to install older versions of RouterOS on RB450G. Older versions simply doesn’t have support for this new board.
what’s with 3.13?
What’s new in 3.22:
*) added advanced switch features for RB450G;
So, don’t downgrade just for this alone. A lot of stuff was added for RB450G in later versions, if you want it to work correctly, use a recent version.
but as i bought the routerboard the 3.11 version was installed on it by default.
i wanna return back the to 3.11 , i hate 3.25…
I’m sorry that you hate this version, nothing I can do, I guess, but support will be available only if you use the latest version that includes all fixes
Where did you buy a 450G with 3.11?? That OS is almost a year old the 450G was announced in February of this year (released and shipping much after that.) . Are you sure it is a 450G and not just a 450? Also if you look at http://tikdude.com/wp-content/uploads/2009/04/routeros3-release-lifetime-in-2008.png It should tell you alot… I would not run anything before 3.20 at worst case.
OK , but the problem is only with the LATEST VERSION (VERSION 3.25) that’s why i wanna downgrade to a lower version.
if you will email support, they will help you solve the problem. this is the logic that should be followed always. downgrade without notifying support will not get your problem solved, and will bring back problems of older versions. you would be forced to stay on the old version, because support will not know about your problem, and nobody would fix it.
I have explained my problem with version 3.25 in the first post.
and the support of mikrotik reseller said that that’s a bug in version 3.25 and does not have any solution to resolveit.
very thanks to Ehsan Vahdati how help me to find out the solution .
and the solution is : IF YOU WANNA DOWNGRADE VERSION 3.25 THE ONLY WAY IS TO FIRST UPGRADE TO VERSION 4 AND THEN DOWNGARDE TO ANY VERSION .
THAT’S THE PRACTICAL SOLTION WHICH WORKED FOR ME !!!
Hi there.
I have similar woes with 3.25 - it just keeps restarting every 30minutes or so.
Did you loose any setup info going from 3.25 to 4 - back to 3.24(i assume) ?
EG - did it connect up - no loss of interface addresses etc ?
Hi there.
